Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 10-07-2005, 04:43 PM
jbkleash jbkleash is offline
what is the normal running temperature?
I have a 2000 Sahara and I think it is running hot...around 210. Does anyone have info or a temp there wrangler runs at?
Old 10-07-2005, 07:09 PM
jea12 jea12 is offline
Re: what is the normal running temperature?
I Have The Same Problem With My 89 Islander
I Put A New Thermostat In It And It Didn't
Change.let Me Know If You Find Out.
Old 10-07-2005, 08:06 PM
GreenJeep10's Avatar
GreenJeep10 GreenJeep10 is offline
Don't touch or change anything. This is the normal operating temp of the vehicle. I have a 97 Sahara and it has run that temp since I got it in 97 with 20,000 miles on it. It now has 113,000 and no troubles.
Old 07-25-2006, 10:42 PM
djmann02's Avatar
djmann02 djmann02 is offline
Same here. Runs a touch below the 210 mark doing 55 mph and slightly above the 210 when I get on the interstate and do around 80 mph. Guess it is normal but would think that a slightly cooler engine temp would be better. Has anyone tried installing a 180 stat?
djmann02's Avatar
Old 07-26-2006, 11:29 AM
tomvid tomvid is offline
Lightbulb Re: what is the normal running temperature?
I wouldnt go anything lower than OEM. The machine is deigned to take a 195 degree thermostat. I wouldnt change it. Although, if it takes a 195 thermostat you would think that is what it should run at. 210 does seem to be a little high. It could be a worn out fan clutch that is not pushing max air through the radiator ( I have seen this before )
97 Jeep Wrangler SE 2.5L
Things I've repaired:
Thermostat: Crankshaft Position Sensor: Radiator: Water Pump: Fan Clutch: Wires: Dist Rotor: Dist Cap: Plugs: Disc Rotor: Pads: Sway/Stabalizer bar links: Axle Shaft U-Joints : Transmission swap : Brake line : Shocks : Rear Pinion Seal : Transmission Mount
Old 07-26-2006, 11:35 AM
Mine runs dead at 195-200 degrees. Never higher.
Old 02-21-2009, 11:29 AM
laniermason laniermason is offline
All Jeeps with a 2.5 4cylinder has a high temperature thermostat in it because the air that is needed in the carberator induction system has to be that hot for the little engine to not skip. I've had people use a lesser temp thermostat and they brought it back for a skipping problem.
Old 03-12-2009, 05:38 PM
BLAZERBOY69 BLAZERBOY69 is offline
Smile Re: what is the normal running temperature?
195 is what the tstat opens at. your temp sensor is a little closer to the block than the tstat, and so reads a little higher than the 195. i have had it this way since i bought it new in 99, and now have about 174k miles on it. no problems so far.
