Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 11-24-2003, 03:10 PM
hdsalinas hdsalinas is offline
Questions about my new (to me) 1999 Corolla
Hi,
Hi I recently purchased an used 1999 Corolla Automatic) and I have accumulated some question after one week of use.
Here is the list of questions/problems that I have discovered so far.
Rear Suspension,
The rear tires seems to drift to the right when going over small bumps. It feels like they were loose or something. Also the rear tires rub against the wheel well when the rear seat is occupied while going over a speedbump.
Could this be faulty shocks?
Radiator fan
If you stand facing the engine compartment (front of the corolla) you will see two electric fans attached to the radiator. the one to your left turns on as soon as you turn the key to "on" and will remain that way regardless of the car`s temperature.
The fan to your right never turn on.
What should be the normal behaviour?
Also the temp needle always stays just below the middle. For example if you turn the engine when is cold in the morning the needle takes only about a minutes to get back in the middle.
I doubt this is normal although the engine is not overheating.
What should be the normal temp position?
Drivetrain
Ihave noticed excesive noise from the front wheels while the vehicle is in motion. If you accelerate the car form 0 mph you hear a little "clinking" noice for a couple of seconds copmming form the right wheel until the car is over 5 or 10 mph.
Could this be caused by due to worn CV Joints?
One more thing, My corolla is missing a plastic cap that goes over a button located above of the shifter`s "PRNDL1" initials.(not the OverDrive switch)
What is this for?
I know that these are a lot of questions, but I really need you help
thanks
Hector David Salinas
1999 Corolla (american version)
San Pedro Sula, Honduras
Old 12-01-2003, 05:08 PM
CadetLee CadetLee is offline
Re: Questions about my new (to me) 1999 Corolla
Your tires shouldn't rub at all..I have a 1.8" drop and still nothing rubs. I can't answer your other questions, but the guys over at www.vvti.net probably can =)
Old 01-28-2004, 03:52 PM
SUPERCOROLLA SUPERCOROLLA is offline
Send a message via AIM to SUPERCOROLLA
Well The Tire Rubing Is Proply Due To Rong Tires On The Car Or Bad Struts ..
The One Fan Will Go On And The Other When The Ac Is On Only ...
The Noise Can Be A Number Of Things Like No Shims On The Brake Pads Loose Caliper Rotors
Old 01-28-2004, 03:53 PM
Old 01-29-2004, 05:11 PM
toyco toyco is offline
The button above the shifter could be a safety type device. I think that it might release the lock so you can shift out of park if the switch stops working that allows you shift when you step on the brake.
Bad wobble, 1999 corolla VE Dale_p Corolla/Matrix/Voltz 4 12-30-2009 10:57 AM
Question about door glass for 2008 corolla steve-- Corolla/Matrix/Voltz 6 01-04-2009 09:26 PM
question about engine swap of 89 corolla pkboy Corolla/Matrix/Voltz 0 04-25-2007 03:41 AM
Questions about my 4AF '89 Carb'd Corolla |PuNiSh3R| Corolla/Matrix/Voltz 2 11-08-2003 02:01 AM
All My Questions About Cars(Please Help Me) jarjarblinks Engineering/ Technical 8 06-26-2003 01:17 AM
