Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 12-28-2009, 11:30 PM
Dale_p Dale_p is offline
Bad wobble, 1999 corolla VE
My passenger side front wheel wobbles when I go past 60 MPH. The wear pattern on the tire is limited to the outside edge of the tire, but is not uniform. The inside edge is worn just like the rest of the tires, they were all bought new together.
I jacked up the front right end, and pushed on the tire to find that it shifts quite easily about 2 inches towards the front of the car, but only when I push on the forward part of the tire, as in I'm facing the tire and pushing on the right. The suspension assembly moves with it and bangs against the inside of the wheel well.
My question is what do you think is broken, and where can I find literature detailing how I would fix it? I'm going to go to a junk yard to pull the parts off an old corolla and fix it myself.
Old 12-29-2009, 12:48 AM
Re: Bad wobble, 1999 corolla VE
*update* I believe have solved most of, if not all of the mystery. The strut mount on that side is torn, allowing the shock absorber assembly to rattle around at the top. I'm hoping replacing this will solve the wobble problem.
Old 12-29-2009, 11:41 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Sounds like a broken strut mount and/or upper strut. The whole assembly will have to be removed to replace it.
You'll need a strut spring compression tool...if you have never done this be very careful! There's a lot of force stored in a compressed spring. Do this outside in a clear area...or better yet, take the assembly to the auto shop and have a pro replace it for you.
Finally, you're always better off replacing suspsension parts in pairs. And after you're done, have an alignment done on the car. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 12-29-2009, 11:56 AM
Thanks alot! I'm rather short on cash, any chance I can get away with just replacing the strut mount for now?
Old 12-30-2009, 10:57 AM
jdmccright's Avatar
The RustBuster
If it's just the strut mount that has failed and the strut itself hasn't been damaged from it banging around, then you can probably get away with it. But an alignment is recommended after replacing any suspension or steering components.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Tags
corolla , suspension , tire , toyota , wobble
