Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 04-06-2003, 10:03 PM
|PuNiSh3R| |PuNiSh3R| is offline
Send a message via AIM to |PuNiSh3R|
Questions about my 4AF '89 Carb'd Corolla
In mid December (2002) I bought an '89 Corolla coupe.
Very nice car, the owner maintaned it pretty good.. perfect interior except for a crack on the dashboard. Anyway I bought it at 99085 on the odometer with a pretty nice audio system for $780.
This car has the optional sun-roof installed which seems to be far and few between on these cars since I am desperately looking for replacement parts.
Anyway, I've been doing work on it recently.. not exactly replacing parts, except I did the sparks (replaced with NGK's), distro cap, rotor, and wires. I've changed the oil just the other day with Castrol 10w40. I've changed the oil.. um.. 2 other times.. so It has a 107K on it now.. I've really driven this car hard. It's my first car.. what do u expect? lol...
I am doing a forced intake on the carb with a 550CFM fan and using 4" thin-wall PVC pipe from the front up to the carb. Yesterday I cleaned the carb out with Valvoline carb and throttle body cleaner. Rev'in the engine steady at 6K while my friend sprayed it out. This worked well.. I noticed at times while he was spraying the peddle was goin insane and the RPM's would go up to 7K by not even pushing the peddle down more.. I had to let off some to stop it from red-lining (at 6,400 I think it is).
The carb is clean as a whistle now.
I am looking to get more power out and I think once I put the fan and the new intake on the carb that should help.. but not do the trick completely. I am not looking to drop major dollars now.. as I don't have major dollars. I am more interested in a reliable sturdy car as of now. I am completely re-wiring the audio system cuz the guy that installed it did a horrible horrible job on the electrical aspect of it.. and even the audio wiring.
I was watching this truck show on TNN today and they put a propane mod on a diesel truck. Basically having propane inject into the air-intake. I was designing with a friend this exact same methode a few months ago. Except my idea used sort of a refrigeration technique to get chilled air in and then putting propane in the mixture as well.
I was just wondering if anyone here could tell me the effects of putting a propane mixture in the air intake on a gasoline car. I am assuming that it will give me a nice boost.. nothing to big though, i'm not hoping for a NOx out-come here. But obviously vapor form propane put under heat, pressure, and then the added spark from the plug will blow just like gas.
My worries, everything is stock still.. I can't put in to much propane in the mixture. I don't want to blow the heads.. camshaft.. etc. So I was going to position a 20lb tank in the trunk.. run the line up and tap it into the PVC pipe intake.. just a few inches from the carb intake.. take it out to a parking lot.. put it in neutral and drop a tiny bit of propane in.. see what happens with the RPM's.. then drive it.. hit the valve open again just for a split second.. see what happens.. I know I can't do to much cuz I don't want to run into knocking.. etc..
I have worked with propane before and I am aware of the safety pre-cautions as well as specs on propane and all that hippy shit.. I used to do refrigeration work and I charged systems with propane as the refrigerant.. works very well.. very comparable to R-22 .
SO any idea's if this will work on a gasoline engine? Also, can anyone give me any performance tips for this car? I am not looking to lower it.. I ain't exactly into the whole dropping the car to the ground mods.. I like my cars beefy and mean.. I ain't looking to do 103489720389493MPH.. just get some more power (HP) out of it.. as well as acceleration.. it can be sluggish now and I really don't know why.. sometimes it takes off.. sometimes it's like.. ugh.. I don't wanna get up ! but then as the RPM's climb it will just take off.. so idk.. I would be willing to take the pistons out and all that shit and clean the engine out and what not..
Thanks bunches for reading this long arse post!
Man with hand in pocket all day feels cocky
Old 04-07-2003, 01:59 PM
Anyone??
Old 11-08-2003, 02:01 AM
Bulldog1657 Bulldog1657 is offline
Cant help you out there bud...but I thought i would say I have a 89 4AF Corolla (Carberated) Sedan...same cars for the most part.
Question about U.S. Corolla Crishpen Sprinter 9 01-17-2005 03:39 PM
quick question about '89 silvia/s13 christophv 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 09-17-2004 12:56 AM
Questions about my new (to me) 1999 Corolla hdsalinas Corolla/Matrix/Voltz 4 01-29-2004 05:11 PM
Question about engine swap for '89 Honda Civic honda888 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 07-13-2003 09:50 PM
question about a 86 nova/corolla puckmanc84 Corolla/Matrix/Voltz 0 04-15-2003 11:55 AM
