Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 11-24-2003, 11:36 AM
johnaldridge johnaldridge is offline
Question 1986 Ranger Fuel problem
I have a 1986 ford ranger 2.3L fuel injected standard.
It was having a hard time starting in the mornings, but once I got it going, it was good for the day. Then it completely died on me. So I changed the wires and plugs, put on a new distrubutor cap, did a compression test that was fine, changed the oil. Still nothing. I then put in a new fuel filter and HP fuel pump. The fuel pump in the tank is whirring. Gas is going into the cartridge the filter rests in. It still will not start. If I add gas to the intake manifold, it will, but dies as soon as the gas is burned up. Does anyone know what my problem is. I am VERY frustrated at this point. I would appreciate any advice.
Thank you
Old 11-25-2003, 09:10 AM
Ranger88 Ranger88 is offline
Re: 1986 Ranger Fuel problem
Sounds like the fuel line is clogged.
Old 01-31-2004, 10:31 PM
dskilgore dskilgore is offline
Lightbulb Fuel Problem
Both my bronco II's have 2 fuel pumps one in the tank then a booster in the frame.
Check the booster pump, It is usaly located underneath in the frame channel on drivers side. I do believe there is a fuse also for it in the fuse box.
1993 ranger has issues dimwittcaddy Ranger | Courier 3 04-23-2009 09:46 PM
1993 Ford Ranger fuel problems rangerdanger21 Ranger | Courier 3 02-09-2009 06:14 PM
98 Ranger fuel problems? phleck Ranger | Courier 2 08-13-2004 01:10 AM
88 Ranger fuel problem wewildbill Ranger | Courier 1 07-22-2004 10:08 PM
1993 Ranger fuel problem borderqueen Ranger | Courier 5 05-17-2004 12:31 PM
