Old 11-23-2003, 10:06 PM
cornob cornob is offline
lumina wont start please help
i brought a lumina yesterday iwas told it had been sitting for about a year so i put a new battery in it it still wouldnt start so i sprayed some starting fluid in the carb it started right up then i drove it around aND IT RAN GOOD THEN I WENT TO GO START IT THIS MORNING IT WOULDNT Start i sprayed some more fluid in the carb it still wouldnt start then i poured some injector cleaner and some stuff called stabill in the gas tank still wont start can some one tell me what could be wrong or what has gone bad or needs to be changed since its been sitting that long its a 1990 lumina 3.1
Old 11-23-2003, 10:34 PM
Bruticus's Avatar
Bruticus Bruticus is offline
Send a message via AIM to Bruticus
Re: lumina wont start please help
Maybe its the starter, or the altenator does the starter make noise when u try to start her up? If its the starter my fathers old remedy for that is to whack the starter with a hammer funny as it sounds it worked for me. The carberator maybe clogged up since its not a Fuel Injected car.
Old 11-24-2003, 12:30 AM
where is the starter located at and can you give me detailed instructions where its at
Old 11-24-2003, 01:55 AM
Retardo Retardo is offline
The starter is in the front of the engine. If you climb under the car (might have to jack it up to have clearance), you'll see a big black canister with a smaller black canister on top of it. This is your starter. The little one is the solenoid and the big one is the starter (or maybe it's vice versa). Either way, both has to come off to replace the starter.
The location of it should be on top of the sub-frame in the front of the engine. They are a real bitch to get off without dropping the sub-frame, so it will take some time to take it off and put another one on.
Old 11-24-2003, 09:40 AM
what sound does a starter make when you know you need a new one
Old 11-24-2003, 10:24 AM
Blaze420 Blaze420 is offline
Send a message via MSN to Blaze420
Everyone else on the forums told me you couldn't have a carburetor on a 90' Lumina.
Old 11-24-2003, 12:11 PM
The 90's are EFI, which is fuel injected. I've yet to see a '90 3.1 with a carb
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 07:00 PM
93 Si Wont Start!!! Please Help!!! hatchbacksi '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 8 08-26-2004 10:27 PM
93 Lumina - rough starting, please help! lustofdecay Lumina 0 08-11-2004 09:27 PM
help!!! car wont start please help bambam89lx '88 - '91 Civic | CRX | Wagon | Shuttlee 9 02-10-2003 03:06 PM
car wont start please help OneTimePoster Engineering/ Technical 4 08-31-2002 08:18 AM
