| Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems. |
Best turbo for b16 civic
Whats the Fastest spooling turbo avaliable for a b16? whats the best turbo for highest hp output for a b16?
Are you looking for a kit or are you going to piece it together? How much hp are you looking for? There is no single definitive answer for these types of questions. How muuch are you looking to spend. A small tdo4 or tdo5 will get you quick spool but will top out quickly limiting the amount of hp, where as a t3 or a t3/t4 won't spool until 3k rpms but will continue to boost you till redline. Is the block going to be built is also another question you need to answer.
93 accord - jdm h22a 2003 srt-4 - daily driver |
Re: Best turbo for b16 civic
well, i most likely won't build the block but i may. I'm looking for about 250whp nothing to fast. I want boost at a reasonable rpm range... so basically i want full boost before 4500rpms++
Re: Re: Best turbo for b16 civic
Then get you a turbo timer and boost controller(I'd go electronic but you can go manual) blah blah blah after install I'd say it'd all cost you around say 2500 bucks if you look in the right places and you'd have a very powerful and lost lasting kit.
Well, you aren't likely to get 250whp from the block unless you do some head work at the minimum. Going with a t3/t4 you would most likely be able to get full boost by 4500 rpms, they don't start spooling up til about 3k rpms, but it is a bit overkill for how much hp you want. They can support up to 500-600 hp depending on your wheel sizes. That and it will cost you more. If you want quick spooling and full boost by 4.5k rpms, go with a tdo5 18g. They are fairly inexspensive and will support the hp you are looking for. Like the other guy said, it's usually cheaper to piece the stuff together. Find a local shop that can do your piping for you. You should get an intercooler also which can be spendy if you don't look around. The tdo5 comes with an internal wastegate actuator so you just need to find the right manifold. I don't know what year of civic you got, but with 250hp you are gonna be hard to touch. Just make sure you get some good fuel management and bigger injectors also. There is always a lot more to turbocharging than just slapping on the turbo.
Re: Re: Re: Best turbo for b16 civic
[quote=93hybridaccord]Well, you aren't likely to get 250whp from the block unless you do some head work at the minimum. QUOTE]
Dude, look around. There are many people getting over 300whp on the stock block. TUNING! |
Re: Re: Re: Re: Best turbo for b16 civic
[quote=maxspeedhonda]
Re: Re: Re: Re: Re: Best turbo for b16 civic
Re: Re: Re: Re: Re: Re: Best turbo for b16 civic
Re: Re: Re: Re: Re: Re: Re: Best turbo for b16 civic
Thats all I have to say, I am going on vacation, be back in a week and a half. |
u should check out the complete drag turbo kit for ur car. it is nicely set up and is made customized for ur ideal car. i am a dealer of the kit so i can hook u up pretty nicely on a kit hit me up if u are interested
T3 .60/.63.....perfect turbo for what you are looking for. dont buy a turbo made for 400+whp if you only need one for 250whp
not to mention .60/.63's are cheaper...
Peter Gibbons: I don't like my job and I don't think I'll go anymore. Joanna: You're just not gonna go? Peter Gibbons: Yeah. Joanna: Won't you get fired? Peter Gibbons: I don't know. But I really don't like it and, uh, I'm not gonna go. Joanna: So you're gonna quit? Peter Gibbons: Uh-uh. Not really. I'm just gonna stop going. Joanna: When did you decide all that? Peter Gibbons: About an hour ago. Joanna: So you're going to get another job? Peter Gibbons: I don't think I'll like another job. Joanna: Well what are you going to do about money? Bills? Peter Gibbons: You know I never really liked paying bills, I don't think I'm going to do that either |
250hp atw can deffinatley be broken, 300hp atw is easy with just a set of pistons and nothing else, you can even do that with all stock internals. my only point is WHY? it is alot cheaper to go ahead and spend $1500 installed for pistons, and rods, so you know it is safe. VS. doing it w/o and taking the chance of blowing a rod through the block or braking the ringlandings off the pistons and sucking metal though the entire engine resulting in a full teardown either way. sometimes it is cheaper to spend the $$$ up front rather on the tail end. hindsight is always 20/20. maxspeed is correct tuning is everything but it never hurts to be safe.
what's the difference between a regular turbo and a ball bearing?
what's the difference between a regular turbo and a ball bearing? I also want a turbo that will effectively hold the amount of boost near redline
