Go Back   Automotive Forums Car Chat > Renault > Clio/Clio II/Clio III
Old 11-23-2003, 12:47 PM
wirrallad wirrallad is offline
Send a message via AIM to wirrallad
clio heater
hi i have a 1991 clio 1.4 rt
and the heater just does not get hot at all in the car i have changed the thermostat could it be anything else or is it just possible that the new thermostat could be faulty or wrong temp range
please help as the winter is now here it is horrible to drive with hat and gloves on
many thanks
lee
Old 11-23-2003, 02:42 PM
mechy1barry mechy1barry is offline
Re: clio heater
if no bleed niples fitted,remove right hand heater pipe.(looking under bonnet.) start eng and let water run out until no air bubbles.keep topping up water!
Old 11-27-2003, 03:24 PM
clio heater
tried removing heater pipes etc... to remove air
it hasnt worked all the pipes are getting red hot and doesnt seem to be any air in the system is it worth trying the thermostat again or you think it may be a blocked heater radiator
Old 11-28-2003, 01:11 PM
Re: clio heater
if both the heater pipes are hot ,the water is flowing through the matrix.check to see if the flaps inside the heater are opening,
Old 12-01-2003, 02:14 PM
Re: clio heater
well it looks like the old clio might have died (RIP) It started leaking water bad from behind the exhaust manifold area at the weekend i removed one of the exhaust manifold bolts and the water was coming out from behind them think the head gasket may have gone now someone said could be £500 upwards so might scrap it now seems a shame its a lovely little car
does it sound terminal to u ?
Old 12-01-2003, 02:19 PM
Re: clio heater
possability of a core plug rusted out,realy hard to tell,but further stripdown should tell.
Old 01-25-2006, 06:47 AM
dylanpugh dylanpugh is offline
Re: clio heater
I have a Renault Clio 1.2 Oasis - the Heat inside the car is at best Warm.
I have changed the thermostat, changed the water pump, flushed the system through with water, and with radiator flush, but it's no different.
The only time I can get HOT air through is if I run the car for a while with the FAN blower Off, then switch it back on - then I get about a SECOND of hot air.
This to me suggests that the water isn't circulating - but as I have said earlier, I've changed the water pump and flushed out the system ??? Can anyone help. [email protected]
Old 12-05-2009, 08:12 AM
savannah2006 savannah2006 is offline
Re: clio heater
have u changed heater matrix behing dash?
1997 Clio Airbag + wiring diagram casahit Clio/Clio II/Clio III 1 12-03-2010 04:54 AM
AC / Heater Fan speed Switch ibkafn8ed Cherokee 0 07-05-2009 02:26 PM
Heater Hose fitting stripped lewisxlove Town Car 1 07-03-2009 08:59 AM
06 Expl Heater Fan stuck full blast/can't stop! Kirkwwhite Explorer | Explorer Sport Trac 3 04-02-2009 09:17 PM
Williams Engine into an old Diesel Clio mikeburton Clio/Clio II/Clio III 0 03-13-2009 01:18 PM
