Old 11-22-2003, 01:52 PM
kidrolla kidrolla is offline
Send a message via MSN to kidrolla
b16a need help
i have a crx wth a b16a gen1
there is a CEL...
the code is calling for a fault in the coolant temp sensor, (1 of the 3)
there is no break in any wire from the engine to the ECU, and all of the sensors check out fine, after checking them each for resistance with a meter..
the ecu is in limp mode, and has a 7200 RPM redline as a result...
no vtec, but the spoon VTEC controller with take care of that..
the car runs strong, but only up to 7200...
we have worked for SEVERAL hours trying to trace it , but the bug IS JUST NOT THERE, no matter where we look... we tried like 3 ECU's, and there is just NO problem to be found..
anyone have any insight?
Old 11-22-2003, 04:40 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: b16a need help
So have you tried to replace the coolant sensor?
Old 11-22-2003, 10:06 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
your ecu might be bad also. take a known good working ecu and plug it in, see if that clears the problem.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 11-23-2003, 01:08 PM
ive done tried 3 ecus and new sensor still check engine
Old 11-23-2003, 01:40 PM
crxlvr's Avatar
did you reset the ecu after you replaced the sensor?
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 11-24-2003, 06:45 PM
yup
I need help!! Cade.Garrett Car Buying Q&A 1 06-04-2009 07:07 PM
B16a needs help! Injectors,fuelrail,fuelpump 96DxSi Let's get Technical! 0 05-25-2004 10:37 PM
need help with my B16A custom86Lx-i Engineering/ Technical 3 04-04-2003 02:58 PM
Need help ! B16a into a 93 Civic essex Engineering/ Technical 10 03-23-2002 12:51 AM
