Old 11-21-2003, 01:06 PM
goyal99 goyal99 is offline
1G Eclipse ECU gone bad??? (photos)
Hello everyone
I'm not sure if my ECU ('91 Eclipse GS 2.0L non-turbo) is toast but I took it out and opened the box....There's a black area (look at the photos below) which seems "burned" or damaged and the rest of the ECU brain looks fine.....
BTW, my car is crancking fine but it will not start (no spark, fuel okay) so that's the reason I suspect the ECU might have gone bad. I have no idea what might have caused the ECU to burn some leads. Anyone??
Any comments will be appreciated....Any way to test this ECU??
http://www.geocities.com/baisden44/1...pse_1G_ECU.jpg
http://www.geocities.com/baisden44/1...se_1G_ECU2.jpg
VK
Old 11-21-2003, 02:24 PM
kjewer1 kjewer1 is offline
AF - Advisor
The links dont work. Unavailable for viewing.
Some poeple can repair ECUs, but they are often only found in local DSM groups, etc. Its usually easier just to get a used one from a junkyard. There is a company that repairs and sells used DSM ecus, but I cant remember the name... Check out the "electrical" section at www.vfaq.com, and search the typical DSM sites (dsmtuners and dsmtalk) to see if you can find it.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-21-2003, 03:59 PM
Re: 1G Eclipse ECU gone bad??? (photos)
Sorry about the links not working.....Try the one below....it should work
http://f2.pg.photos.yahoo.com/baisden44
95 eclipse gs blue smoke won't start hcruz32 Eclipse Problem Diagnosis 1 03-20-2009 09:36 PM
ECU gone bad, help me find replacement PLEASE djpattiecake Del Sol 2 01-15-2009 11:40 PM
New to eclipses, got a 1993 eclipse gst with bad bottom end?? jslamerman Off-Topic 1 08-05-2005 05:54 PM
Oh no! My Eclipse has gone rice! ;) lol carweb Graphic Manipulation 6 08-29-2004 04:17 AM
my ECM or ECU has gone bad boosting20psi Off-Topic 1 01-07-2004 02:23 PM
