Old 11-20-2003, 10:46 PM
jackass30 jackass30 is offline
clutch problems 99 t/a help!!!!!!!!!!!!!
hello i have a 99 t/a 6speed it seems when im on her hard
the clutch gets tighter and tighter then the pedal will not come all the way back up. causes me to miss gears and you know you dont wont to miss gears next to a stang.i can pull the pedal back up with my foot
but on take off it still feels funny until i run through the gears slow
Old 11-20-2003, 11:21 PM
BadAzz240's Avatar
BadAzz240 BadAzz240 is offline
Send a message via Yahoo to BadAzz240
Re: clutch problems 99 t/a help!!!!!!!!!!!!!
hmm, check your fluid in the clutch master cylinder. You may be low on fluid and your system may need to be bleed out. Maybe you will get lucky and you wont need a clutch but chances are shortly after something like this happens you usually end up needing a clutch. But start with that other stuff first.
Just for the Stroke of it...
Old 11-22-2003, 11:33 AM
Re: Re: clutch problems 99 t/a help!!!!!!!!!!!!!
hey bad thanks for the help i already checked fluid did not bleed though
i will do that. is it true center force clutches are cheaper than a factory clutch?
clutch problem..i think bov3220 Engine, Transmission and Drivetrain 4 05-22-2009 12:17 PM
HELP!! clutch problem Dusto 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 11-01-2003 05:39 PM
Clutch problem with '03 Accord 6MT - HELP! TheFreshmaker Engineering/ Technical 3 10-27-2003 07:28 AM
who can help me with my clutch problem importbling '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 06-12-2003 05:12 PM
Clutch Problem.. PLEASE HELP hangcool Integra 0 09-02-2002 12:49 PM
