Old 06-10-2003, 11:02 PM
importbling importbling is offline
who can help me with my clutch problem
I just finished having my brakes done and i was driving down he road, everything seemed fine until I stop at the bank to check my balance. I got into my car and I could not get the damn thing into the gear, I had the clutch as far as it would go, I tried it in reverse, it just kept grinding the gears, I turn the car off and I had to force the stick into first gear, even then when I started the car it want to die and pop the stick out of gear. Basicly its this, the car is off, It's hard to put into gear but managable. The car is started, it's impossible to put into gears, what can I do?
Old 06-10-2003, 11:14 PM
BullShifter's Avatar
If your car is hard to get into gear, let the clutch out for a second & then try getting the gear.
Did they take your car for a road test?
Old 06-10-2003, 11:18 PM
tried
I tried like hell for about an hour to get it into gear, It just wont go? You think it could be the throw off bearing? I dunno?
Old 06-11-2003, 04:13 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Check your clutch fluid.
Old 06-11-2003, 03:25 PM
candlaudio candlaudio is offline
Send a message via Yahoo to candlaudio
well your throw out bearing could be bad but also your slave cylinder may be gone to which is what pumps the fluid and all so you might want to check that. and like the other guy said check your fluid.
Old 06-11-2003, 03:42 PM
michaelsd16c michaelsd16c is offline
I had the same problem. My car wouldn't start in first so I put it in second and it started. But when I would drive it and put it in third it pop like if somthing wasn't grabing(gears)I took it to a clutch shop and they told me that one of the spring had pop out and that's why it wouldn't grab the gear.But before I had all this trouble my car wasn't that bad i would have trouble sometimes putting it in first gear only.It's like no matter how hard I trird it would go in to first.. My clutch finally went out after 3month, I mean the spring pop out. the shop told me that I still had plenty on the cluch.But beware when you go to a shop they might say it's the tranny not the clutch or they might also say your clutch is out to and you have the get a new clutch and tranny. I know this becuase the guy that work on my car said first that it was a tranny problem but because he knows my dad, he called back the next day and said it was only the clutch. I say this because he told me that alot of times when this happens to people THE SHOP"S say it's the tranny and the clutch when really it's only the clutch......know what I mean $$$$$
Old 06-11-2003, 09:12 PM
ok well i have a question for ya i pretty much think i know what it is but someone else'e advice or input......well anywho's here goes....my trannyonly grinds in second when im moving and if i try to put it in first while rolling it will grind but all the other gears are good, no grinding at all..........i think it is gonna be the synchronizers for second.....but if anyone knows something different please let me know
Old 06-11-2003, 11:03 PM
You should never downshift to 1st gear while rolling, maybe a couple 2 or 3mph - nothing more.
Old 06-11-2003, 11:41 PM
How do you know that it is the tranny and not the clutch?Did you try putting it in second gear to see if it will start?Did it work?For some reason I think It's your clutch. I really think that you should get it check out.Grinding......that sounds really BAD!!!!!!!!!
Old 06-12-2003, 05:12 PM
well i never downshift to first unless im coming to a stop in which im usually doin about 2 or 3 miles an hour, but as for second it grinds on the downshift and upshift so am i right in saying it is the synchronizers....also i have a stage 2 clutch in it
Anyone here who can help with ABS light on an '02? Fortune50 Tahoe 3 03-09-2007 07:42 PM
Anyone good with comps in here, who can help me? Killa_DSM COMPLETELY off-topic 6 08-30-2004 12:10 AM
who can help with this stuff? tomekeuro85 Grand Prix 6 12-27-2003 01:49 AM
anyone who can help with b16 prob... jNYCe5 '88 - '91 Civic | CRX | Wagon | Shuttlee 5 12-16-2002 06:51 PM
Pls who can help with Tamiya paint awaken1973 Car Modeling 0 01-12-2002 12:52 AM
