Old 11-20-2003, 05:02 PM
Mojoe Mojoe is offline
Question B16A header for CRX
Swapping a b16a into a 91 CRX HF. When I buy the header what vehicle should I reference? I emailed DC Sports and they said any B18 vehicle ( 90-91 Teg, 92-93GS/RS/LS/GS-R..etc) will work, problem is I don't have the cabbage for a DC. I called Hedman and Summit and they didn't have a clue..yes i'm gonna run a Tork Step Chikara. What do you guys think...DC, Hedman...brand name shouldn't matter as far as the application?
Old 11-20-2003, 05:08 PM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
Source the header for your B16A from any B16A equipped car. I used the 99-00 Si. I recommend DC, it's a quality product for the money. Be advised, however, that the DC Sports 4-1 header requires you to bash the f*ck out of your crossmember for it to fit (you have to remove it just to install it w/ the motor inside your car). The 4-2-1 DC header should fit fine.
The B18 headers will hang lower, and thus you'll have even more ground clearance issues (the 4-1 B16 DC header is bad enough). They hang lower because the b18 blocks are 7mm taller than the B16. Get a 4-2-1 DC Sports header from an Si and call it a day.
PS- Will you be upgrading to a heated 4 wire O2 sensor...or do you have a chipped ecu that eliminates your secondary O2, so you can just run your single wire primary O2?)
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
pm5 pm5 is offline
I would go for the DC.
Old 11-20-2003, 05:34 PM
SiZ's Avatar
SiZ SiZ is offline
If you're not going to get AT LEAST DC, then I don't see the point of even getting one at all. DC is the minimum I would buy. Best header for your money would be a JDM ITR, just a JDM DC header.. Something with the 2.5" collector.
"The nympho of info, I'm fuckin' what ya heard"
Old 11-20-2003, 05:41 PM
Re: B16A header for CRX
Heated 4 wire O2? Thought I would install 1 O2 near the top of the header and the other near the cat...tapping into existing wire...not plugs but wires.
Old 11-22-2003, 05:50 PM
Fishcat37's Avatar
Re: Re: B16A header for CRX
if you're going to keep the 2 single wire O2 sensors....then you need to have an O2 bung welded in. There is only one bung on the dc header.
Appearance Mods:
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-MSD SCI-L ignition
Interior Mod
Former Cars
'94 Integra GS-R
'96 Camaro
best header for b16a salchichon20 Let's get Technical! 5 07-19-2004 02:08 AM
Header for Crx w/B16A Crxflippr Engineering/ Technical 4 07-22-2003 10:31 AM
DC Sports Headers for a B16A (1) Setanta '88 - '91 Civic | CRX | Wagon | Shuttlee 2 08-05-2002 12:33 PM
DC vs Type R headers for b16a CRX586 '88 - '91 Civic | CRX | Wagon | Shuttlee 20 07-18-2002 04:56 AM
