Old 11-19-2003, 07:51 PM
trboboosted trboboosted is offline
Post Installing apexi n1 on 95gst
If anyone has installed apexi n1 catback on a 95gst please help. I unbolted stock exhaust ok, it was a little difficult pulling the muffler section out through the small opening of the wheel brace or whatever the name of it is. I had to hammer the bottom of the trunk in a little to allow enough clearance for the section where the three bolts go to come out. The apex pipe off of the back of the muffler will not fit back through that opening. No way. Dude said,where I bought it from, it should bolt up easily. Others said the same thing. the only way of this working would be to completely unbolt that brace and the arms of the left rear wheel, bolt the exhaust up, then bolt the brace and arms back up. Is this the only way or am i wrong? I have a 2inch drop but should that matter? The other two sections of the apex exhaust look to bolt up fine. Any help would be greatly appreciated
Old 11-19-2003, 08:43 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
by taking off the wheel it makes it a lot easier unless you have a car lift!!!
Old 11-19-2003, 11:19 PM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
its kinda late and i'm not sure if I read your post right,
but it sounds like you're trying to put it over the axle like how stock exhaust was mounted.
the N1 goes under the axle
-Agim
Old 12-04-2003, 09:51 PM
95gst 95gst is offline
Send a message via ICQ to 95gst Send a message via AIM to 95gst Send a message via Yahoo to 95gst
Re: Installing apexi n1 on 95gst
wassup man? i recently installed an apexi n1 downpipe and catback system on my 95 gst.... it was pretty easy except for the end part bc i have 3" piping cat back and a 4" outlet. The part where the gas tank is in the back i could not go over the rear end and under the tank, it would not fit(a 2 and a half would prob fit barely).. I had to put it under the rear end and it sits pretty nice, doesnt bottom out or nething... if you have any questions feel free to email me @ [email protected] or go on aol instant messanger and im me @ kryptonight33... lataz
Need help with tachometer install! AHHKILLA Eclipse 2000+ 0 05-03-2009 11:04 PM
99 Passat Radio Installation DouganAFife '97+ 0 04-15-2009 09:42 AM
Whats the best way to install side skirts? Sonic Eclipse Exterior and Wheels 8 04-06-2009 11:51 AM
installing aftermarket cd player jwhite85 General Discussions 3 03-30-2009 11:52 AM
Cost of installing APEXi N1 eclipsered Off-Topic 8 06-03-2004 11:57 AM
