Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 11-18-2003, 05:37 PM
95mushroom 95mushroom is offline
Send a message via AIM to 95mushroom
Angry starting problems, just turning over
Hello, new member, lol.
Anyways, my 95 is developing a starting problem. It did once a while ago I and never gave it a thought. But now it seems more common.
Whats its doing is that after like an hour or two of sitting after driving, the engine just turns over and times an ungodly amount of time to fire up. Then I guess, two or so cylinders grab and pull the rest of the engine to start. I'm thinking it has something to do with the fuel as it turns over nicely. Also, the cure-all for this Aurora's seems to be the Fuel Pressure Regulator which I havent replaced yet. I just did plugs/wires/coils last week so it cant be anything that way.
Anyone else have an idea?
Old 11-18-2003, 07:53 PM
Indy8's Avatar
Indy8 Indy8 is offline
Re: starting problems, just turning over
Yeah, what kind of plugs? Gapped at what? Please read my post in the "Valuable Northstar" thread.
Old 11-18-2003, 08:22 PM
dafrazi dafrazi is offline
Possibly Fuel Rail
I had the same problem. It wasn't easy to trouble shoot. I replaced the fuel pressure regulator but the slow starting problem persisted. What finally tipped me off was a gas smell around the fuel injectors. I took it to my mechanic who said there was a pin-hole in the fuel rail. Hopefully for you it is the pressure regulator becuase the fuel rail isn't cheap-about $350.
Old 11-19-2003, 03:49 AM
Indy8's Avatar
Re: Possibly Fuel Rail
If you need it, get the GM metal upgrade rail kit. $135, take you a couple of hours.
Quality isn't expensive, it's priceless.
Old 11-28-2003, 05:06 AM
RorthStar RorthStar is offline
Send a message via Yahoo to RorthStar
I had a simfuel pumpilar problem also. Turned out to be the fuel pump. Easy fix, you don't even have to drop the tank! Unfortunately, it's a 200 dollar part! part no 25029709. Anyway, hope you find out what the problem is! later!
Old 11-28-2003, 11:21 AM
Indy8's Avatar
Re: Re: starting problems, just turning over
RorthStar, how did you R&R the fuel pump w/o removing the tank? The dealer insists that tank has to come out to do this. And what is acceptable fuel pressure in PSI?
Old 11-28-2003, 01:59 PM
jjdewd jjdewd is offline
Send a message via AIM to jjdewd
thought I read you can access the fuelpump through the trunk
Old 11-28-2003, 10:26 PM
Bill V Bill V is offline
There is a nice tin plate in the right side forward area of the trunk. It is under the mat. Easy to access, but you need a special tool to remove the sender lock ring.
Old 11-29-2003, 01:39 AM
Indy8's Avatar
That's right.....now I remember someone saying to be patient using a small punch and hammer to loosen it.
Old 11-29-2003, 09:35 AM
BKVic's Avatar
BKVic BKVic is offline
Indy8
According to ALLDATA the fuel pressure for a 97 Aurora should be between 48-55 PSI. I would guess that it would be the same for the other years between 95-99.
BKVic
Old 11-29-2003, 10:50 AM
Indy8's Avatar
That's pump pressure, measured before the reg.,or what the reg. should be sending? I was wondering what min. acceptable pressure is when checking for a bad pump.
Old 11-29-2003, 11:34 AM
BKVic's Avatar
Thats what you should be reading at the fuel rail while the pump is actually running. They say you may have to cycle the ignition switch off and on a couple of times to get the highest reading. The fuel pump should run for about 2 sec each time you cycle the switch to off and then on agian. I tried to cut and paste but the ALLDATA site wont allow it, Sorry.
BKVic
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
starting problem, doesn't turn over at all Bencher600 Roadmaster 3 04-14-2007 02:41 PM
camry 1988 wont start? just turns over ROSSD898 Camry/Camry Hybrid/Vista 4 09-23-2005 03:54 PM
93 probe gt won't start just turns over carissa_099 Probe 7 04-23-2005 10:58 PM
