Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 09-19-2005, 12:57 PM
ROSSD898 ROSSD898 is offline
camry 1988 wont start? just turns over
hi there, thanks for your input, i have a camry 1988 sv21 engine , it wont fire up it cramks oner i changed the ecm module,but still wont spark over it has a very low spark on the plugs...
Old 09-19-2005, 01:49 PM
Orangecrate Orangecrate is offline
Re: camry 1988 wont start? just turns over
Take off the distributor cap. Have someone watch the rotor while the engine turns over. If the rotor doesn't move the timing belt is broken.
Kep
Old 09-23-2005, 01:07 PM
Re: Re: camry 1988 wont start? just turns over
Kep
THANKS FOR YOUR TIP .I HAVE ALREADY CHECKED THAT HINT, I APRICIATE YOUR HELP, THE TIMING BELT IS OK, THE ROTOR IS OK ITS A NEW ROTOR BUTTON, WHAT IT DOES IT JUST CRANKS OVER AND NO NOT FIRING, THERE IS A SMALL SPARK ON THE 4 SPARK PLUGS , ...I AM LOST ITS A TRICKY ONE
Old 09-23-2005, 02:48 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Check the coil. These generation 2 Camrys have a history of defective coils. They develop a hairline crack over time and short themselves to anything metal inside the distributor.
Mike
Old 09-23-2005, 03:54 PM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool
I wrote a guide for Brian's FAQ.
Try that
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
