Go Back   Automotive Forums Car Chat > Ford > Probe
Old 04-09-2005, 12:41 AM
carissa_099 carissa_099 is offline
Send a message via AIM to carissa_099 Send a message via Yahoo to carissa_099
93 probe gt won't start just turns over
its not getting any spark. i had the tranny done and now it won't start... it just turns over and over. i have replace plugs wires cap and rotor... distributor sensors... if theres something i am missing let me know. it is for sure getting fuel though. i just can't figure it out and i am getting really sick of driving my boyfriend to work!!!!
Old 04-09-2005, 08:24 PM
bargersaudio bargersaudio is offline
Re: 93 probe gt won't start just turns over
Did you check the fuses? There is a fuse panel by the battery that has a few fuses in it that could cause a no spark and also at least one fuse under the dash (labeled engine) in the fuse panel. It is very possible when they pulled the tranny they shorted a wire that blew a fuse. Let me know there might be a few other things to try if not a fuse.
Old 04-09-2005, 10:47 PM
we checked those.... they're all fine... any other sugjestions would be great!
Old 04-10-2005, 01:20 AM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
might be your alternator, have you tried to boost it? And if you just had the tranny done and it doesn't work take it back and tell them to fix it.
93 FORD PROBE GT
JDM manifold ported match
65mm TB
Unorthodox Underdrive Pulley
Hotshot headers
3' Exhaust all the way
No cat
Cold air intake
K&N air filter
Short throw shifter
Eibach lowering springs
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Performace Wires and Plugs
Synthetics
Performance Rad and fan
Mild Weight Reduction
Coming this week:
Performance Heads and Cams
3 angle head job
Why does everyone have to piss on Ford.
Old 04-12-2005, 01:38 PM
could this just be a ground problem??? a wire that was screwed up with installation on the tranny? if so anyone got any ideas as to where the stupid wire is cuz i can't find it.... thats what it kinda sounds like to me.... let me know ppl!thanks
Old 04-12-2005, 01:42 PM
i paid someone else for installation. the guy who did the tranny doesn't install. he only warranties the tranny itself and not the installation.
Old 04-19-2005, 12:39 PM
mikentc90 mikentc90 is offline
I have bad news for you, it is going to cost an arm but not a leg. Your problen is more than likely your Igniter. This is located in the Distributor. It is the round flat plate that has a plug that is on the outside of the distributor. price is just over $300.00.
Old 04-23-2005, 10:58 PM
PimpinProbeGT93 PimpinProbeGT93 is offline
i had this problem and all i did was tightin the bolt right on top of the ignition(spelling) and it started right up
17 and got a probe gt with MSD wires and intake catback exhaust
i love this car better than my old civic
