Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 11-13-2003, 08:50 PM
atwsgs atwsgs is offline
Engine dies, but will restart--need help?
The engine dies completely, but will restart immediately and run for
a few miles then dies. Makes no differents at what speed or at a
stop light. I changed the DME relay which made no differents.
I've been told it could be the DME control unit---
could some one whos had a similar experience let me know what
they did to correct. Thanks
Old 11-16-2003, 04:14 PM
baker84 baker84 is offline
ECU Unit or DME
I had the same problem with mine. It would just die on me and then I would have to tap on the ECU Unit(DME) in order to get it started.. Sounds to me like its your computer. I bought one for $100.00 used from Part Werks
Old 11-25-2003, 11:21 PM
SentrieONE SentrieONE is offline
Send a message via AIM to SentrieONE
Re: Engine dies, but will restart--need help?
yeah...i have the same problem with my 951, whats the link to part werks? on 944online.com they sell rebuilt dme units for $400 or so...
Old 11-27-2003, 11:24 PM
Cbass's Avatar
Cbass Cbass is offline
Send a message via ICQ to Cbass Send a message via AIM to Cbass Send a message via MSN to Cbass Send a message via Yahoo to Cbass
It could be a number of other things as well, start by replacing your fuel filters, because it's cheap, and you should do it anyways
Connor - Porsche Nazi since 2001, VW defiler since 2004
This here's a Fabrication forum!
My lugnut requires more torque than your LS1 makes.
Old 12-03-2003, 06:58 PM
89Turbo944's Avatar
89Turbo944 89Turbo944 is offline
Ya, deffinetly replace fuel filters. Like Cbass said its cheap and easy and probably needs to be done. Another thing you could do is hook up a air/fuel ratio guage. And moniter your air fuel ratio. If its low you probably have a clogged filter or possibly a dieing fuel pump.
But it could be the computer unit. Try the cheap and then spend the $$ to fix it
Good luck
1990 4X4 3.6 troubles hard to start and it dies but will restart with in 5 to 10 mins montanatimberwolf Dakota 0 07-26-2009 06:24 AM
99 Avalon, engine turns, but won't fire, need help! BD-Nebr. Avalon/Pronard 4 06-01-2008 10:46 PM
97 Lesabre dies, will not restart, but will restart later. No codes Smith1000 LeSabre 10 07-26-2007 07:59 AM
Cougar just dies but will restart after setting eeezeegoin76 Cougar 0 06-02-2007 10:15 AM
