Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 07-26-2009, 06:24 AM
montanatimberwolf montanatimberwolf is offline
Question 1990 4X4 3.6 troubles hard to start and it dies but will restart with in 5 to 10 mins
dakota 3.9 4x4
replaced the following Parts
AIR filter,fuel filter,coil, rotor and cap,spark plugs, Fuel pump, battery,thermostat, heater sensor, battery, Replace battery clamps,
got the codes they are 12 11 33 and 55
11 no distributor input signal
12 memory standby power lost
33 A/C Clutch cut off relay circuit
55 end of codes
I do not have an A/C so dose not matter!
power lost battery was disconnected dose not matter i do not think!
No distributor input signal I think that is causing the trouble! what is it and where is it at .... It know the Distributor is it a bad part in side it? or what?
the temp gauge is not right when the trouble started the coil leaked oil!
I had replaced that and i replaced all the other parts i had listed!
I had blow 2 more coils since then! meaning they are new and started to leak oil all so!
back to the temp gauge! when it is off the temp gauge is over Half way!
when I am trying to start the pickup the temp gauge returns to normal!
I had all so noticed the battery is all way wet on top of it! so i checked the before i try to start it it is dry!
what is the trouble you think?
and please do not say fuel pump I had checked out the fuel pumps throw the local auto parts stores and both those pumps are good and in Dodge Spec.
troubles... when the dodge starts it will run like 5 mins and stalls out like NO GAS. and sounds like it all so when an out fit runs out of gas...
It is getting spark I had hooked up a spark tester to the coil to the cap!
Do not have a plugged in fuel line Blow it out with air .fuel filter to throttle body.. I unhooked the fuel line at both ends was opened !
if i leave it run like 30 to 40 mins i can restart it and drive it all the time! and will not stall out.
could it be the pick-up coil? if so would it cause it stall out like running out of gas and make that sound like running out of gas? and would it cause the temp gauge go hot when it is not running?
If that is the case! what would be an easier way to replace it?
Here is a other ? 3 more dumbing lights is on the brakes and under the brake light and some other 2.... those lights been on all ways is that normal?
hope some one can help me!
if some one need to know what a code number means let me know and i will look it up in my book.... I do not believe those codes 33 means A/C clutch I do not have an A/C and the heat dose work
code 12 means Power lost just means the battery was un hooked
11 I want to be leave it could be right! 2 is not right so it is hard for me to trust any codes if it tells you some thing you donot have!
55 means end of codes
