Old 11-13-2003, 11:41 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Best place to take oil feed from...
Well, I'm trying to put together my turbo kit, and wondered where is the best place to take my oil feed line from. On my Z6, the stock oil press. sensor is not being used, so I could take it from there easily, but it's a small port, and I don't know if it would be enough to feed a turbo. Also, it's right next to the vtec solenoid, and I don't want to rob the vtec of its oil feed either. Also, I have heard of people taking it straight off the oil sending unit. What have you turbo kids out there done? I have also heard of getting the ring adapters for oil pressure sensors that come off the oil filter fitting. Just curious what is the best way to go...
I can't wait to have boost!
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 11-13-2003, 12:46 PM
91civicDXdude's Avatar
unscrew the oil sending unit from the back of the block and T into the line.
Old 11-13-2003, 02:21 PM
4GZChatch's Avatar
Re: Best place to take oil feed from...
when you say the oil sending unit, do you mean off the oil pump, or is there another spot that I'm not aware of? I have never really known what people meant by that... I should have been more clear in my first post...
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 11-13-2003, 08:21 PM
Worshp's Avatar
Worshp Worshp is offline
Sending unit is at the back of the block (firewall side) and above the oil filter.
I'm doing this as well, just can't remember what size socket to use???
best place to buy from - kit? hardcoresilence Prelude 0 01-13-2003 09:49 PM
orderin an h22 off net....which place is best to get the h22 from Atariallstar Engineering/ Technical 11 10-10-2002 10:54 AM
Best place to buy from ?! HyOctane Engineering/ Technical 2 08-28-2002 04:41 AM
Best place to order mufflers from? bobbyd '88 - '91 Civic | CRX | Wagon | Shuttlee 2 08-19-2002 01:16 PM
Best place to take a Road Trip in Cali DarknessRS California 6 05-20-2002 07:11 AM
