Old 11-12-2003, 05:21 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Oil Pump?
Within the last couple days ive been noticing that when I start my engine up, it kocks like 3-4 times then runs fine. I was thinking that maybe it was the oil pump going bad. Today I went for a little drive and all the sudden the oil light came on. I thought it was just way low on oil because my car burns oil so without any thought I put some in it then checked the dipstuck. It was over the fill mark so thats not why it was on. Did id go on because my oil pump is shot? Oh yea one more thing, the light is only on at idle, when im driving or just rev up the engine it turns off. Please help me, I dont want to ruin my new ZC.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 11-12-2003, 05:47 PM
bigben21 bigben21 is offline
Send a message via AIM to bigben21
ok first thing to do is take off the oil filter, this one your going to need a friend and some brake cleaner. once you got the oil filter off crank the car have a friend to check if there is oil coming out if there is you oil pump should be ok. put the filter back on and clean the area good with brake cleaner get all the oil off next thing to suspect is wrong is the oil pressure sender unit right above the oil filter just replace that and see if that help. get back to us and lets us know.
Old 11-12-2003, 08:26 PM
Thanks man, you have no idea how much I appreciate your help. Im so low on cash right now so any ways that I can check this stuff out myself are really helpful. Thanks again. Ill let you know what happens.
ZC stuff
Old 11-12-2003, 08:34 PM
i forgot to add dont let the engine run or crank for to long dont want to run the engine dry
Old 11-12-2003, 08:43 PM
Do you know about how much a new sender unit will cost?
ZC stuff
Old 11-12-2003, 09:30 PM
hard to say i never bought one i work at honda though i get that hella emlployee discount i get everything at cost. ill check a price for you tommorrow if you want me to? email me [email protected]
Old 11-13-2003, 11:50 AM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
Re: Oil Pump?
Upgrade to a VTEC oil pump, it pumps out more oil than your ZC oil pump and it bolts right on. It will run you about $130 from honda.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 11-13-2003, 03:19 PM
Re: Oil Pump?
Prolly a dumb question, but do I drain the oil before taking the filter off and testing it like that?
ZC stuff
Old 11-13-2003, 05:23 PM
Exclamation
Alright, well I havent done that test yet but I was just out driving a little and now every time I idle, the car stalls or just fights to stay running. Its almost like the alternator because the headlights get dim and it dies. Its even worse when I have my brights on. Whats the deal?? Please help!
ZC stuff
Old 11-13-2003, 07:59 PM
ok calm down it may be your oil pump going out (oh by the way dont drain the oil before doing the test in fact overfill the engine by a half a quart) your crank is probally getting hard to turn. but a way to check the alternator is to let the car run and then take off the neg side battery cable if the car is still running your alternator is good if it dies as soon as you take the neg battery cable off you alternator is shot
93 bird 3.8L oil pump replacement issues capndoodoo Thunderbird 1 03-27-2009 09:20 PM
1.8t oil light turbo problem or oil pump deadkat '94 - '01 0 07-12-2004 11:47 AM
Removing oil pan to change oil pump?????? OzzyMamma Dakota 1 04-21-2004 03:18 PM
possible oil pump problem ,slow oil pressure on cold engine 71chevydude C/K 0 03-22-2004 05:11 PM
Bad Oil Pump? No oil in valves? hgallegos915 Cavalier 6 03-13-2004 12:34 PM
