| View Poll Results: Can you help me | |||
| comments |
0 | 0% |
| questions |
0 | 0% |
| ideas |
0 | 0% |
| Voters: 0. You may not vote on this poll | |||
I have an rx-7 non-turbo stick with major problems
My car is pumping too much fuel into the cylanders and my plug keep fouling out and carbonizing. I changed out the top igition coil, oxygen sensor, spark plug wires and plugs, went through and checked everything i can think of. It is a bitch to start and idles in the 500s. Back it is olny running on the bottom cylanders and the top is doing nothing. I know the ground to engine is a problem and i checked it throughly. Vaccume is checked and engine is not blown. I has power olny 1/4 the way through the peddle. Im in the kansas city area and if anyone knows someone i can take this car to please e-mail me.i have no idea what the problem is and i have went through everything i can think of. i need help please!!!!!!!!!!! [email protected] |
Re: I need mechanical Help PLEASE
No cylinders, mate. I dunno what you mean aobut the "top" and "bottom" cylinders, but it sounds like your throttle position sensor may be off. It could also be a whole host of other stupid problems. If it is indeed too much fuel, check out the injectors, the intake and whatnot.
If by "top and bottom cylinders" you mean leading and trailing spark plugs....how did you determine that the REAR ROTOR is only running on the bottom(leading spark plug).
What kind of spark plugs are you using?
-1987 Mazda RX-7 Turbo II- Voted #7 in the top 10 cars in 1987 by Motor Trend! -Driving Sideways Since 2001- |
Okay, do you have a timing light? Because we need to verify your spark. Secondly, how many miles on the car? Have you put aftermarket injectors in? Possible you have a bad injector (most fail to the closed position, but you never know). WHATEVER YOU DO, use NGK PLUGS~!!! And third, your a rotary owner. You dont have the following: Pistons Cylinders Timing Chains Heads etc... Jarrett
1988 10th AE Edition TII More mods then you have. |
Hold on now I just put those ngk plugs in my car now I can notice the car has a miss in it at around 3000 rpm. Also put some huge wires on I got from mazdatrix. Whats up?
It's probably the classic 3800 RPM hesitation.
Does your stumble happen at 3800?
