Old 11-09-2003, 06:02 PM
divingduckman's Avatar
divingduckman divingduckman is offline
Angry #3 spark plug removal on 97 blazer
Does anybody know how to get the #3 spark plug (driver side middle) out on a 97 Blazer 4x4? I have replaced all the other ones but came to this one and the steering shaft is in the way. I can get the socket on but that is it. I've tried putting a universal on and no luck. Also I’ve tried using a wrench on the socket and no luck. Do I have to drop the shaft???? ANY HELP WOULD BE APPERICATED. Thanks
Old 11-10-2003, 06:17 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
I do
O.K. that was cruel.....remove the tire and wheel assembly and go in through the wheel well.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-10-2003, 10:22 AM
Tried that but the steering column is still in the way.
Old 11-10-2003, 01:05 PM
mobzs's Avatar
mobzs mobzs is offline
Send a message via MSN to mobzs
#3 spark plug
move\remove the dip stick, and cut alittle off of the heat shield. that should give you access. hope this helps
Old 11-10-2003, 01:13 PM
GMMerlin's Avatar
I know stuff
Re: #3 spark plug
I haven't needed to remove or modify anything to remove #3 plug.
It might be the brand of socket you are using..I have found that a Snap-On flex spark plug socket works like a dream.
If you don't have time to invest in the tool, the only other thing is to drop the steering shaft.
GM WCT
PM Me for details
Old 11-10-2003, 01:49 PM
Re: #3 spark plug removal on 97 blazer
How hard is it to drop the shaft???? Also is the socket you’re talking about just a spark plug socket with a built on universal???
Old 11-10-2003, 06:22 PM
GMMerlin's Avatar
I know stuff
Re: Re: #3 spark plug removal on 97 blazer
Unbolt the shaft from the steering gear and slide it out of the way.
Yes, but I have found that different manufactors sockets are a little different from each other...the Snap-on is more rounded at the universal and will slide past the shaft...my Mac socket wont fit....
GM WCT
PM Me for details
Old 11-11-2003, 12:07 PM
Thanks Merlin went to sears last night and bought that socket. Worked like a charm. Thanks for all the help everybody.
Old 12-11-2003, 10:19 AM
sthomas193 sthomas193 is offline
Send a message via AIM to sthomas193 Send a message via Yahoo to sthomas193
I Just Did This On My Wife's 1997 Bravada...should Be The Same For Your Blazer...you Need To Get A Spark Plug Socket With A "hex" End On It And Break It Loose With A Wrench, Then Remove The Wrench, Remove The Socket And Turn It Out The Rest Of The Way With Your Fingers, Reverse The Procedure To Install The New Plug. You Have To Remove The Socket Or It Will Hit The Steering Shaft Before You Get The Plug Loose.
Hope This Helps...
spark plugs freakyfire05 ZX2 2 02-17-2009 11:03 AM
2003 Tacoma spark plug removal wrigley123 Tacoma 14 08-10-2004 03:59 AM
spark plug removal btk55343 Escort 4 06-23-2004 01:33 AM
2000 chevy blazer spark plug removal boss101 Blazer 4 06-07-2004 05:39 PM
spark plug removal debi riley Montana/Montana SV6 0 12-13-2003 08:10 PM
