Old 11-09-2003, 09:11 AM
Dwiese Dwiese is offline
Angry Low beams won't turn on
2000 GT. started out when you tilt steering up lights come on. tilt down they go off. Ah, must be short in wiring harness. Dealer installed new harnes ($623.00) easy but expensive fix for them. About 3 days later did same thing. Checked(and replaced) fuses, DLR and relays. still no luck. Dealer wants to put in new ignition (around $389.00) Someone help me before I dump more into this problem than what this car is worth. For a $1K I could hook up a toggle switch and run a direct wire to the low beams and and then be able to drive this car at night again. works on my sand rail!!
Thanks Dan
94 Lincoln Continental: Lights won't turn off TheWampusCat Continental 8 01-12-2014 10:56 AM
low beams won't work...HELP uscrebel Cavalier Problem Diagnosis 3 11-19-2006 01:35 PM
high beams won't turn off... veroq Sable 1 11-19-2005 02:26 PM
3rd Gen Camaro High Beams Won't Turn Off AegisJones54 Camaro Discussions 10 08-13-2005 03:11 AM
low beams won't shut off on 97 PA PAgal97 Park Avenue 1 03-09-2005 11:37 AM
