Old 11-08-2003, 10:49 PM
myeclipseisnicer myeclipseisnicer is offline
Send a message via AIM to myeclipseisnicer
Engine check light
ok this thread is for my uncle's civic, he has a 96 dx 5 speed...his engine light is on and he doesnt have the funds to take it to the dealer or put any money towards it to get it off, is there a switch or a button or a way to turn it off? please let me know thanks i appreciate it
Old 11-09-2003, 12:23 PM
BullShifter's Avatar
Re: Engine check light
To reset the check engine light you need to locate the under-hood fuse box, then pull the Hazard fuse for 15 seconds. Also the negative battery cable can be disconnected but you will loose the radio memory & possibly the anit-theft code. If it is an anit-theft radio, make sure to have the code before disconnecting the battery - Pulling the fuse is the best choice for a reset.
If there is a problem the light WILL return until the problem has be properly fixed.
2005 Hybrid with recurrent engine/IMA lights SheltieMan '01-'05 Civic 1 07-14-2010 08:54 AM
Oil Check Light FordBoss88 Caravan | Voyager 3 01-18-2010 08:56 AM
Engine CHeck Light on ~ engine shakes a lot (rpm too low) My90AccordEx Accord/TSX/Accord Hybrid 4 01-12-2004 07:47 PM
resetting the ecu and engine check light vietfella Accord/TSX/Accord Hybrid 7 04-18-2002 01:24 PM
engine check light? Drocca91 Accord/TSX/Accord Hybrid 5 01-14-2002 03:29 PM
