Old 11-08-2003, 10:24 PM
ccfbnj86 ccfbnj86 is offline
Send a message via AIM to ccfbnj86 Send a message via Yahoo to ccfbnj86
bigger engine
is there a bigger engine that produces more HP and will fit in the car?
Old 11-08-2003, 10:26 PM
Re: bigger engine
in the 04 spyder gts
Old 11-08-2003, 10:59 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: bigger engine
no not really. hte 04 eclipses kinda sux.. you can spend lots of $$ and build a custom turbo package..
1
Shift_BOOST
97 s14
Old 11-08-2003, 11:01 PM
kjewer1 kjewer1 is offline
AF - Advisor
You can convert the 2.0 to a 2.3 stroker or install a 2.4 liter block with the 4g63 head. Thats about it.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-09-2003, 12:11 AM
2of9 2of9 is offline
u can put a 1 gen block in to a 2 gen 4g63-T...i think...i dunno if i even said it write...(am i right???)
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 11-09-2003, 02:57 AM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
umm, doesn't the GTS have a 3.0L V6?
-Agim
Old 11-09-2003, 03:09 AM
AF - Advisor
Re: bigger engine
You can do that, its called the 1gina2g swap using either the RRE or the more popular Magnus method. But its the same size as the 2 motor
The trick is to put a 2.4 liter crank in the 2.0 liter block with 1g or upgraded rods, and custom pistons like the 8.5:1 weiscos made for this hybrid. You end up with a 2.3 liter. The other option is to convert a 2.4 liter block from some mitsu/hyundia cars to work with the 4g63 head and swap that block in for a true 2.4 liter.
Kevin Jewer
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
bigger engine 97cutlass712 Cutlass Series 3 04-13-2004 03:46 PM
bigger engine ccfbnj86 Grand Cherokee | Grand Cherokee SRT8 0 11-23-2003 09:50 PM
A question: ECU for bigger engine Sparco 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 1 09-20-2002 05:08 AM
i need a bigger engine thrilla92 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 04-30-2002 12:39 PM
