Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 09-18-2002, 04:12 AM
Sparco Sparco is offline
Question A question: ECU for bigger engine
300ZX Fairlady Z Z32 twin turbo 07/90
Here it is
Now I have 2 engines: one stock, and one dead now (burn through piston due to injector malfunction) so the cylinder block should be repaired and the pistons should be changed
A suppose that a can use pistons from 3000GT twin turbo ( dia 92mm) instead of mines (dia 87mm) so than the cylinder block should be turned till dia 92mm, am I right? I already got 2 metal gasket from greddy-trust for such diameter of pistons
So the question is: could the motor work properly with the larger volume? I think it will be 3,350 liters with standart ECU but with fuel regulator, fuel controller, boost controller and same shit????
thanks to ALL
Old 09-20-2002, 05:08 AM
SlowNLow SlowNLow is offline
Send a message via AIM to SlowNLow
well it's going to change your compression there for changing boost I'm not sure how to figure all that but I'm sure there is somewhere you can find out.
**ALWAYS FOR SALE**everything has a price tag
300zxtt
Pic's in link....
http://www.webphotos.com/list_photos...&smi=1&a=78756
If interested please PM
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
Need a bigger engine for 67 Nova newtoit34 Engineering/ Technical 4 09-08-2006 08:12 AM
F20B Sir engine tranny and ecu for sale generation 6 Accord/TSX/Accord Hybrid 6 11-16-2004 10:35 AM
WTB Need TT wire Harness and ECU for DOHC engine PDFFlyer Classifieds 0 09-29-2003 11:39 PM
