Go Back   Automotive Forums Car Chat > Isuzu > General Discussion
Old 11-08-2003, 02:05 PM
tsunami420 tsunami420 is offline
Angry 92 pick up idle problem
put a new thermostat in last weekend, and everything went fine until the other day my idle now surges. it almost stalls out at the valley of the surge. does anyone have any idea what could be causing this, i don't think it has anything to do with the thermostat???
Old 12-20-2003, 09:47 AM
5speeder 5speeder is offline
Re: 92 pick up idle problem
Hey tsunami did you ever figure this problem out because I have the same problem??????????????
Old 01-06-2004, 10:54 PM
vrwconspire vrwconspire is offline
I had a rough idling problem and checked the carbs. There was a hose disconnected (small diameter, black) and also the the hose heat return hose (going from valve cover to air intake unit). After connecting these and a dose of Sea Foam top engine cleaner, no more problems.
Old 07-26-2004, 12:53 PM
desmarkus desmarkus is offline
I have the same problem too, with my 92 rodeo 3.1.
I've spent over a year changing parts with no luck. I finally just turned up my idle to reduce the stalling. still idles rough though.
Not so lucky with the hose though, I don't have any vacuum leaks.
When I unplug (electrical) my map sensor it idles good (although would be impossible to drive) but I changed it and still the same thing.
2002 Chevrolet Venture, 3.4L 6Cyl. 4 door (4 speed automatic)
1997 Dodge Caravan, 3.0L 6Cyl. 4 door (3 speed automatic)
- Des Markus
Old 11-30-2004, 03:04 PM
evofan74 evofan74 is offline
Send a message via Yahoo to evofan74
I am having an idle problem on my 1992 pickup. I have changed everything I can think of. I think I am going to do a head swap or total rebuild. I love the truck but it idles like it has BIG CAMS, and it has NO power....
Old 04-02-2005, 07:50 PM
b65pauls b65pauls is offline
Exclamation Idle problem
I had an idle problem on my 88 carb. Turns out the shaft bushing on the plate that sits under the carb was worn and the result was a vacuum leak. Put water in a straw and slowly let drip on the shaft. Sucked the water right. $40 (bushing and labor) later , at a carb shop, runs fine!
Clio 1.2 16v 2002 Expression idle problem!! stuuuu Clio/Clio II/Clio III 1 05-03-2010 02:59 PM
1987 Grand Marquis 5.0L FAST IDLE problem Johnobub Grand Marquis 3 10-09-2009 08:10 AM
Idling Problem williamjbronski Cavalier Problem Diagnosis 2 08-10-2009 10:39 AM
1995 SL Idle Problem peliknhed LS/LW 1 07-07-2009 07:30 PM
2001 Dodge Grand Caravan ES idle problem Rookie Tech Caravan | Voyager 3 07-03-2009 11:27 AM
