Old 11-07-2003, 08:33 PM
pisco03 pisco03 is offline
Unhappy Elusive oil leak...
Hi all,
I really need some help here!
My 1991 Voyager (2.5L engine) developed an irritating oil leak. I replaced all seals but the leak continues and I can't see where it comes from. It's dripping at a rate of one drop/second, and some of the oil gets on one of the belts and sprays all over the place!
Any help would be very much appreciated!!!!!!
Old 11-10-2003, 09:14 AM
DragonSlayer DragonSlayer is offline
Re: Elusive oil leak...
Sounds to me like the oil leak could be coming through the crank bearings. Have you replaced the seals here? They're not as easy to do as an oil pan gasket.
Old 11-10-2003, 11:22 AM
Re: Re: Elusive oil leak...
Yes I replaces both seals, and the leak continues the same
I put the car on ramps and even looking directly at the engine I cannot see where it comes from, it just drips out of somewhere!!!
Maybe that's the famous "Mistery Oil"!!!!
Old 11-10-2003, 11:31 AM
Wow. That sucks!
Is it possible you have a small fracture in the block somewhere?
Maybe you can clean off the engine with a good de-greeser and see the leak that way. If it is one drip every second, I'm sure you could spot it when the engine is clean.
That is a lot of oil loss!
Old 11-10-2003, 12:31 PM
It is, I'll tell ya...
I saw at PepBoys a kit with some kind of chemical that you put in the oil and with a special light you can see where the oil is leaking from, sort of ultraviolet light against the chem mixed in the oil.
Ever heard of such thing?
Old 11-10-2003, 12:35 PM
Can't say that I have. But I assumed there would be something like that on the market. However, with a leak that fast, I assumed you would be able to see it.
Does it leak only when the engine is running? If not, then the leak must be in the oil pan correct? (I'm not too familiar with Chrysler engines).
Old 11-10-2003, 01:18 PM
It leaks for some time after you STOP the vehicle (and of course when you drive it). In other words when the oil is hot and under (maybe) some pressure. I'm still puzzled.......
The oil pan is intact.
Old 11-23-2003, 07:18 PM
Elrod on the V-Rod Elrod on the V-Rod is offline
Could be excessive crankshaft end play.Idout it because you say it leaks shut down.No pressure shut down.Could be clogged return holes in cylander head.Did you replace the cam seal? The dye will show oil leaks as green.Mainly made for 2 units separatly sealed bolted together like transmission and transfer case that use the same color oils.Put the dye only in 1 unit for examination.
3800 w/ oil leak on top joshhighley Monte Carlo 3 04-20-2010 04:19 PM
Elusive Oil Leak pcmos LeSabre 22 08-13-2009 05:12 PM
Oil Leak in radiator Southern Comfort Camaro Discussions 2 07-26-2009 09:40 AM
oil leak?????? freakyfire05 Accord/TSX/Accord Hybrid 11 02-22-2009 12:44 AM
Elusive oil leak woodygo Prelude 2 11-29-2004 09:03 AM
