Old 11-06-2003, 10:31 AM
dsmitt dsmitt is offline
Question Axle Pops Out of Tranny
My daughter has a '97 Civic Coupe EX stick shift with 70K. Twice the left axle has popped out of the transmission and she has been towed. Both shafts and cv joints have previously been replaced! What is causing this to happen? The shop keeps popping the thing back in for $90. Help!
Old 11-06-2003, 12:34 PM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
that is strange... no where in the travel of the suspension should either of the joints have enough play to pop out of the tranny. since it has been taken to the shop to put back in you would expect that they would notice any kind of serious suspension problem while they are putting the shaft back in. i am guessing you have an incorrect shaft for your car
LS1 RX-7 Zoom Zoom
Old 11-06-2003, 03:26 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Axle Pops Out of Tranny
maybe you have an axle with the wrong number of splines...I'm not sure if that would cause the axle to pop out of the tranny, but then I can't really think of any reason it should
Empty Pockets Racing Member #1
Old 11-06-2003, 03:33 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: Re: Axle Pops Out of Tranny
that's what i was thinkin....wrong axle
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 11-06-2003, 04:01 PM
Miataracer's Avatar
wouldn't be wrong number of splines... if that was the case there would be much more of a problem as the axle either would not go into the tranny at all, or would go in but not match to the teeth causing the splines to just grind inside the tranny
it about has to be too short of an axle...
LS1 RX-7 Zoom Zoom
Old 11-06-2003, 04:58 PM
GScivic7's Avatar
okay, this really far fetched, but does the 6th gen civics use an intermediate shaft? Maybe they aren't using one and just sticking an axle in that is long enough to work, but not long enough to stay in there....
Old 11-06-2003, 05:17 PM
damir831's Avatar
damir831 damir831 is offline
Banned
Send a message via AIM to damir831
Does the shop replace the whole axle or just the shaft? You can get a brand new left axle with everything you need to just replace the whole thing from Autozone for just 60 bucks. I don't know if you can give it to the shop and let them install it for you, but I'd rather pay $50 more and not worry about it, than having to replace the shaft or cv joint every time. Plus, the axle that autozone sells has a lifetime warranty.
Old 11-07-2003, 12:18 PM
93fury 93fury is offline
On the inner boot of the axle, near the end of the splines, on the tranny side, there is a circle ring that goes around the splines. It looks useless, but its actually what "clips" the axle in place. Make sure thats there. If its not, youll know it because there will be an empty groove. Ive learned this the hard way. We swapped the tranny, and installed the new axles. One didnt have the clip. As soon as I got to about 15-20 MPH, it popped out. We had the propper axles, I used them for 30K + miles afterwards, it just wasent fastened.
Old 11-07-2003, 12:59 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
I second the clip idea. I've seen some morons at the shop, but none stupid enough to just slap some axle in there that doesn't fit.
Old 11-07-2003, 11:00 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
I agree, that clip idea sounds like it might be the cluprit. I would be easy for a less than stellar shop not very knowledgable in Hondas to screw that up and leave it off.
Old 11-09-2003, 12:37 PM
BullShifter's Avatar
I have seen axles pop out before. 1 reason is because a new "clip" was used on an old axle - its best to use the old clips unless the axle is replaced. Why? I have no idea, it seems that the new clip would be better to use when it's really not.
If it pops out again, take it to the dealer to get fixed properly & then send the bill to the shop that messed things up in the first place.
Old 11-10-2003, 06:46 PM
b's b's is offline
i'm guessing here but if you have a bad transmission mount or motor mount wouldn't that cause the engine to shift. there for pulling on one side of the axle causeing it pop out or work like it should. try checking your mounts.
Old 11-11-2003, 11:07 AM
If your engine could shift the 6 inches the axle spline is, then you have some serious problems! If thats the case, dont be suprised when your engine falls ont he floor! Doubt its the mounts, probally the clip.
Old 11-14-2003, 03:28 PM
shmaptoe shmaptoe is offline
Send a message via AIM to shmaptoe
i also agree with the clip idea. last weekend i had my castle nut come off and my balljoint came out of my lca- tire went way up into the wheelwell and was not driveable- it ripped my cv joints apart so bad that bearings fell out on the ground, but the axle stayed in the tranny cause the clip was there. because of this nonsense -im on my 3rd axle in the past 3 weeks. thank god for autozone lifetime warranty
for those i love i will sacrifice...
Old 11-15-2003, 03:53 AM
Honda God
Originally Posted by shmaptoe
i last weekend i had my castle nut come off and my balljoint came out of my lca- tire went way up into the wheelwell and was not driveable- it ripped my cv joints apart so bad that bearings fell out on the ground, but the axle stayed in the tranny cause the clip was there. because of this nonsense -im on my 3rd axle in the past 3 weeks. thank god for autozone lifetime warranty
Dude, thats some bad luck there. That sucks. Hopefully you don't get to a forth axel.
cv axle keeps popping out torp3do '88 - '91 Civic | CRX | Wagon | Shuttlee 2 11-16-2004 07:47 AM
help: 96 right axle pop out xingyun '96-'00 Civic 1 10-07-2004 03:34 PM
axle popped out!! jamey666 Jimmy 1 06-09-2004 11:49 AM
Tranny pops out of 5th bassmanmyrl Escort 2 12-11-2003 04:45 PM
Drive Axle Popping out!!! quiXilver '88 - '91 Civic | CRX | Wagon | Shuttlee 10 07-17-2003 11:35 PM
