Old 07-16-2003, 03:58 PM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Drive Axle Popping out!!!
My passenger side axle keeps popping out after I'm in gear for about 3 seconds. Undriveable...mechanic says I might need to check my frame for engine/transmission allignment. Anybody ever had this problem? Prolly not lol but any suggestions will be great appreciated
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 07-16-2003, 08:22 PM
CivicWarrior CivicWarrior is offline
Send a message via AIM to CivicWarrior
so put in a new drive axle... seems simple enough
Old 07-16-2003, 08:23 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
unless the axel is broken there is no physical way for the axel to "pop out" since it it wedged between the transmission and bolted to your wheel bearing.
a couple possibilities are, one of the joints are bad (more than likely your inner joint)
Or
your Differential is cooked... don't feel too bad if this is the case since I cooked mine a few weeks ago.
Kun
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 07-17-2003, 12:11 AM
quiXilver's Avatar
Well I'm about to change both my axles...um what do you mean my differential is cooked? I'm gonna replace my tranny too, think both these will solve the problem?
B18A
Old 07-17-2003, 05:12 AM
Kunundrum's Avatar
the differential is the component in the transmission that gives the power to the axels, if that component is shot... not power get to the wheels.
Old 07-17-2003, 05:44 AM
quiXilver's Avatar
Ain't the differential in the tranny on front wheel drive cars? If that's true then I'm gettin a new tranny anyway. And plus this same problem just happend. The mechanic said he popped it back in when it was on the lift.
B18A
Old 07-17-2003, 08:20 AM
Kunundrum's Avatar
it sounds more like your axels is bad... probably your inner joint.
Old 07-17-2003, 11:21 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
not that easy to just change it and expect the problem to be gone. actually we are having the same problem in hooptie...but the axel isn't popping all the way out. we just changed the axel this weekend. it didn't exactly help. unfortunatly the frame will need to be pulled to fix it.
if you have tools and aren't afraid to get your hands dirty then pull the axel. if not, have a shop throw it on a frame rack and see if the frame is bent...take it from there
http://www.binghamtonlife.com/manual/manual.htm you can check the helm's there to see how to yank the axel.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 07-17-2003, 12:06 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
When reassembling my car after replacing a clutch, I didn't jam the axle all the way back into the transmission. First time I let out on the clutch, the axle popped out a little and stripped a bunch of metal off of the splines.
This might have happened if you had a worn-out 'keeper' on your axle. I forget the technical name for it.
Anyway, it popped out one time and in 30 seconds did enough damage to never go back in properly. Had to get a new axle.
Look at the end of the axle that goes into the transmission. Are the splines ground off?
Might just need a new 'keeper'.
Flunky
'Keeper' = Retaining clip?
Old 07-17-2003, 10:35 PM
quiXilver's Avatar
The mechanic said the clip is fine, he also said that yea I might need to see if the frame is bent, that would really fuckin suck, 'cause I want to sell this car and get an Si.
B18A
Old 07-17-2003, 11:35 PM
amy@af's Avatar
tell me about it! i was pretty pissed when we replaced the axel sunday and it still had troubles i want to sell hooptie to help recoupe for the si we just got jer...i feel your pain!!!
99 CVP71 130K. While driving sparkplug popped out. alotech Crown Victoria 8 06-23-2008 07:32 PM
cv axle keeps popping out torp3do '88 - '91 Civic | CRX | Wagon | Shuttlee 2 11-16-2004 07:47 AM
help: 96 right axle pop out xingyun '96-'00 Civic 1 10-07-2004 03:34 PM
axle popped out!! jamey666 Jimmy 1 06-09-2004 11:49 AM
Axle Pops Out of Tranny dsmitt '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 15 11-21-2003 03:36 AM
