Go Back   Automotive Forums Car Chat > Opel/Vauxhall > Astra/Astra Coupe/Kadett
Old 11-06-2003, 05:01 AM
david doglay david doglay is offline
Angry petrol and oil leak
my 92 vauxhall astra is leaking oil and petrol. how do i go about repair it myself.
e-mail me at [email protected]
Old 11-06-2003, 05:04 AM
911S_TARGA_RSR 911S_TARGA_RSR is offline
Re: petrol and oil leak
First check your lines then fittings on the lines. After that I dont know what to check off the top off my head.
911 Super Targa RSR
[Dual Flow Intake][Twin Turbo][Larger List to Come]
Old 11-13-2003, 07:49 PM
gord3001 gord3001 is offline
you need to think about the problem as two seprate leaks.
Firstly the petrol.
Start by checking the hose that goes from the fuel pump to the petrol tank, they have a habbit of corroding where the pipe enters the tank. if not their then follow all the fuel lines, you should have some idea where to look because thats where the petrol will be on the road or were ever it has leaked to.
When youv'e found where it's leaking from either replace the hose, pump, jubilee clip or what ever needs replacing ....EASY
OIL LEAK. - this could be a little more difficult, again it's really a case in searching then replacing. if you are getting oil on the road where you have parked then chances are that either you oil filter seal has failed (£4- £5 from halfords) or again a hose. or if it is just making your engine bay really messy then its probably your rocker cover gasket that has gone or even worst it might be your sump gasket.
good luck finding the leaks,
oil in spark plugs tube and oil leak out of engine ccastro Accord/TSX/Accord Hybrid 6 06-27-2013 01:02 PM
Oil Leak in radiator Southern Comfort Camaro Discussions 2 07-26-2009 09:40 AM
oil leak?????? freakyfire05 Accord/TSX/Accord Hybrid 11 02-22-2009 12:44 AM
98 Blazer: Cold days, and oil leak! kwjohnston Blazer 7 12-29-2004 02:02 PM
SR20 and Oil leaks Moppie Engine 5 12-16-2001 12:52 AM
