Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 11-05-2003, 07:10 PM
trippy264 trippy264 is offline
amp installayion
on my 95 saturn how do i get the power cable from inside the car to under the trunk anyone have pics or could explain thanks
Old 11-07-2003, 01:09 AM
YellowSC2 YellowSC2 is offline
Banned
I have a 97 SC2, not sure if the 95 is the same or not, but I just ran the 4 guage power wire through the boot that covers the steering rod through the firewall. I just took a pocket knife, and made a small slit in the boot, and then ran the wire through that.
I dont have any pics, and my camera sux or I would take some for ya, but its really easy I am just not sure if the 97 and 95 are the same.....
hope that helps
Old 11-08-2003, 03:08 PM
Re: amp installayion
yea thanks that what i ended up doin but now my amp wont trun onn shitty man
Old 11-12-2003, 05:31 PM
disco192 disco192 is offline
If the amp doesnt turn on you most likely have a remote wire or a ground wire problem.
Take your power wire and lightly strike the ground wire (should make a big spark). Make sure you dont blow your fuse. If it sparks then you have a good power and ground, if not, then that is your problem.
If you get a spark, then try taking a small wire and run it from the power terminal to the remote terminal. The power and remote both carry a DC 12v+ . If it still doesnt turn on, then you have a bad amp. Make sure you take this wire off later because the amp will stay on the whole time.
Hope that helps,
Stu
Stock Radio for installing Subs/Amp? robkule422 Car Audio 8 02-01-2011 07:29 PM
AMP/Speaker wiring in cooler boom box Chupacabra111 Car Audio 6 12-20-2010 05:29 PM
Fosgate Subs and new amp.. kenwood amp blew? viet_boiiiii Audio and Videos 19 01-16-2005 12:10 AM
adding an amp to power new speakers on top of the stock bose amp stef722 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 02-03-2004 12:20 AM
power acoustik amp, great deal, good amp? rendog24 Car Audio 4 04-29-2002 01:48 PM
