Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Audio and Videos
Old 01-09-2005, 08:38 PM
viet_boiiiii's Avatar
viet_boiiiii viet_boiiiii is offline
Send a message via AIM to viet_boiiiii
Fosgate Subs and new amp.. kenwood amp blew?
I just got 2 12" fosgate p2 and a fosgate p3002 amp today. Dam these shit pound on my car haah. Well the problem is, my kenwood amp KAC-5201 is either blown or not powerd up. I had Audio Express do all the work since circuit city charged me too much. Do u guys think my kenwood amp is dead (its only like 2 months old) or do u guys think i should bring it back to audio express and let them check it out? I checked the kenwood amp plugs and everything seemed fine but i dont see the light on.
new 2006 Scion tC - 5spd
-magnaflow catback
http://www.cardomain.com/ride/2088489
~~~R.I.P (7-2-05)~~~
1998 Eclipse Gst - 5 spd
Old 01-09-2005, 08:40 PM
Re: Fosgate Subs and new amp.. kenwood amp blew?
Heres how my new sys looks.
http://server3.uploadit.org/files/Vi...rX-Fosgate.JPG
by the way i still have my stock deck haah.
-magnaflow catback
Old 01-09-2005, 09:43 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
did you check your fuses?
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 01-09-2005, 10:03 PM
The fuses look funny.. il send u a pic of how it looks like when i edit.
EDIT: heres the link to the fuse (its the blue thing that has 15 on it)
http://www.crutchfield.com/S-YRxsqBv...display=XL#Tab
its too dark out now to see if my fuse is blown but i hope it is the fuse cause those things are cheap.
-magnaflow catback
Old 01-09-2005, 10:08 PM
thats easy just pull it out. it probablty also has a fuse closer to the battery
-1stGenRocks-
Old 01-09-2005, 10:14 PM
ok when i pull it out, what should i not or should see? what will it look like if its blown?
-magnaflow catback
Old 01-09-2005, 11:17 PM
SLoe's Avatar
SLoe SLoe is offline
It will be burned open between the two legs of the fuse. Maybe even black.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 01-09-2005, 11:22 PM
Il check tomorrow right after school. You think Audio Express can check it for free for me? i paid them a whole lot to do all that work and i should get a free check right?
-magnaflow catback
Old 01-09-2005, 11:42 PM
SLoe's Avatar
You should, but that doesn't mean you will.
Old 01-10-2005, 02:09 AM
imtheoneandonlyD's Avatar
imtheoneandonlyD imtheoneandonlyD is offline
Send a message via AIM to imtheoneandonlyD
audio is seriously one of the easiest things to fix yourself. Plus if you learn to do it yourself you'll save money down the road when you upgrade and so on.
Just fix it your self. The amp kit fuse should be between the battery and the firewall. Connected to a wire coming directly from the battery.
Pictures of the Truck
Old 01-10-2005, 08:40 PM
Ok my friend took a look at my amp and he said "its gotta be the fuse". he unpluged the fuse from the amp and looked at it.... its still in new condition. Afterwards he pluged it back in and i turned on the power and BAM! the amp is runing smoothly. This was wierd.. i guess it wasnt pluged in all the way the first time. Thanks alot guys.
-magnaflow catback
Old 01-12-2005, 09:42 PM
OMG! today after school i was cruisen home and then out of nowhere my subs and speakers went out. I got out of the car, open the trunk, then saw the sub box disconnected from the amp. So then i pluged everything back in and now the kenwood amp wont work anymore. I took it to Audio express and they said that there was an internal problem and it would cost 90$ for a new amp. WTF!!! i barely got the amp 2-3 months ago and the kenwood warranty says that i have 1 yr of their limited warranty. Should i buy that new amp or just complain to Kenwood and try to get a replacement amp? I dont think i have to pay for a new amp since i did not touch any wires or uninstalled anything.
-magnaflow catback
Old 01-12-2005, 09:55 PM
take it to wherever you bought it and start complaining
-1stGenRocks-
Old 01-12-2005, 10:20 PM
I tried that today.. they said "either go with a 90$ new amp or just leave as is and go home." dam wtf, they installed the amp and sub and speakers so how come it aint working. They should at least fix the amp for me.
-magnaflow catback
Old 01-12-2005, 10:25 PM
did you fill out your warranty card and everything? ask to talk to the manager. be polite but make sure that they know you want THEM to fix the problem
-1stGenRocks-
