Old 11-05-2003, 11:32 AM
cbence cbence is offline
ABS lite & brake lite problems
I have a 1991 F150 Supercab with RABS I (rear anti-lock only).
I have two (I hope) unrelated problems.
1. My brake lite will not go off. I disconnected the plug at the master cylinder and it went off, but it still works when I engage the parking brake. By the way, I know the switch is closed, because I jumped the wires in the plug and the light came back on. I installed a new master cylinder, bled the brakes and I have a full firm pedal. It is full of fluid.
Does this mean the float mechanisim is faulty?? Or, is the proportioning valve faulty??
2. I have lost 1/2 of my RABS diagnostic connector. My ABS lite was on, so I checked the fuse - o.k.. I took the rear sensor out and it was closed - read 1400 ohms. I proceeded to look under the dash to run the "blinking light" test. Lo and behold, the diagnostic connector was disconnected. I found the black/orange wire and ran the test and got 4 blinks ( which according to my manual signals a broken circuit). I decided to reconnect the connector and see if I could get the light to go out.
BUT, I CANNOT FIND THE OTHER SIDE OF MY CONNECTOR. Could I have lost it?? Anyone know where the red wire side comes from or where it goes. Surely it did not just disappear.
Any info would be appreciated.
Thanks,
Chuck
99 e-150 abs lite & brake lite on mjauto Econoline 1 09-15-2007 08:06 AM
1999 Venture ABS, Traction Control & Brake Light Problem andycliff Venture 1 12-22-2006 03:36 PM
engine lite/abs and parking brake lites on miketo Grand AM 1 08-11-2006 12:47 PM
Sporadic ABS & Brake Lights problem myrone Sonoma | S-15 2 07-23-2006 10:23 PM
ABS & Brake Lite On, Cruise & Heater don't work sojim TrailBlazer | Trailblazer EXT 1 11-02-2004 05:54 PM
