Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 07-15-2006, 10:11 AM
myrone myrone is offline
Question Sporadic ABS & Brake Lights problem
Sometimes my ABS & Brake lights go on at the same time on my dash and when they do my cruise control and AC/Heater fan won't work. Any help would be greatly appreciated as this is becoming more of a problem.
Thank you,
Myrone
Old 07-23-2006, 08:21 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Sporadic ABS & Brake Lights problem
Sounds like a ground issue.. But I would also look at the sensor wires and sensors themselves (check for metal shavings) on the hub system itself... (need an alan wrench to remove)
Old 07-23-2006, 10:23 PM
Blue Bowtie's Avatar
Registered Offender
You might also want to inspect the crimped connectionos on the bussing on the rear of the fuse panel. They tend to fail after periods of extended loading. Those should be cleaned, re-crimped, and then soldered to prevent future melt-downs:
