Old 06-06-2007, 07:17 AM
jcc3inc jcc3inc is offline
97 LeSabre EGR problem
Good morning,
Have diagnosed a bad EGR for the 97 LeSabre; the schematic shows a "motor" of sorts to operate the valve with a potentiometer feedback.
My question before I take it off, is "How does the motor work? Is it a solenoid of some sort with a sprivg return, or is it really a stepping motor of some sort?"
I'd like to repair it if possible, or if not replace it.
Thanks in advance,
Jack C.
Old 06-06-2007, 08:53 AM
Re: 97 LeSabre EGR problem
Just checked the unit; it is a solenoid operated device with a simple vee type
plunger valve opened by the solenoid armature motion.
The coil resistnce is 8.3 ohms, the feedback pot has an overall resistance of about 3.77K ohms, the wiper resistance to one end varies from 1.15 K ohms to 4K ohms. Measuring from the other end, resistance varies from 3.46K to 400 ohms.
Couldn't find the plunger sticking, and the pot seemed smooth in traveling from end to end. Also made sure the female connector pins were tight against the pins of the EGR. Have to retry this unit and see just what went wrong.
Jack C.
Old 06-06-2007, 10:11 AM
ChemMan ChemMan is offline
I take it this is the linear type egr valve with a five pin connector. What indicated that the egr was the problem? Was it a set code? Which one? How did you check the egr pot? I just asking because those resistance readings don't look right and I'd like to get an idea of your thought process. Also, you checked the egr pipes for blockage, right?
Thanks
2010 Mazda CX-7 2.5L 12000 miles
2003 Chevy S10 Extreme 4.3L 57000 miles
1995 Buick Lesabre Custom 86000 miles RIP
2002 Pontiac Sunfire SE 130000 miles RIP
1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!!
R.I.P. 1978 Ford Fairmont 83000 miles
Old 06-06-2007, 10:17 AM
Luke. Luke. is offline
From my experience with my '95 Saturn, that GM's EGR valves are very durable, with the usual problem being that they get slightly carboned up. With that said, a good cleaning, with particular attention being directed to the base [ pintle base ] usually is all that is necessary.
BTW, the 'pintle' is what is lifted up and closed during it's operation
1997 Buick LeSabre Limited, with Grand Touring Suspension (72,925 miles) with UIM/EGR Stovepipe leakage issues resolved/repaired
& 1995 Saturn SL2 (498,125 miles) as of 6/19/07
