Old 11-03-2003, 04:22 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Rear camber
My car cambers real bad in the rear and i did a search and couldn't find what I want. I was just wondering if anybody knows the best camber kit for the back. Might as well throw the front in there too. I have Zero1Racing coilovers with a 4" drop in the front and like 3.5 in the back. Any help would be appreciated.
Check out my car here My 91 Hatch
Old 11-03-2003, 09:13 PM
91zc 91zc is offline
I find the washer and bolt method to work the best. Here is a diagram from fourthgenhatch's website and the blue text shows where you should insert the washers and longer bolts on the rear suspension
91 civic 4dr
b16a
14.8@94
Old 11-03-2003, 09:20 PM
Re: Rear camber
thanks man
Old 11-04-2003, 06:10 AM
Alan Wil Alan Wil is offline
Exclamation Re: Rear camber
I would add: Make sure to use high quality grade 8 bolts. The head of the bolt should be marked 8.8
PS: While your in there check the rear trailing arm bushings for play.
Alan
90 Honda Civic DX
2 or 3 washers for rear camber trick? Cackophony Tires and Wheels 7 06-23-2002 09:09 PM
rear camber bolts/washers from home depot RedRacerCivic '88 - '91 Civic | CRX | Wagon | Shuttlee 2 06-17-2002 03:08 AM
Progress rear camber kit?!?!?? strodda Accord/TSX/Accord Hybrid 22 04-08-2002 07:04 AM
Easy rear camber fix ricebooy Accord/TSX/Accord Hybrid 1 04-07-2002 12:26 PM
p11 rear camber alignment kits (eibach vs. ingalls) Nismoboy1 Suspension 4 12-07-2001 01:36 PM
