Old 11-02-2003, 06:37 PM
lbm lbm is offline
okay help
So my mom was trying to explain to me where to find my Spark plugs in my 95 Taurus GL, 3.8L. She was on the phone so she was doing her best I've never had to change my own Spark Plugs so I don't really know what I'm looking for. I know what a spark plug looks like but I don't know what a distributor cap is HELP!!!!!!!!!!! PLEASE!!!!!!!!!!!!!!! Maybe someone can explain it better and maybe I'll listen better because you're not my mother...
Old 11-05-2003, 03:07 PM
Wilson_Shaw Wilson_Shaw is offline
The spark plugs themselves are located on both sides of the engine (three on each side). Since this is a transverse mounted engine, three of the plugs will be facing the front of the car, and the other three will be facing the rear. Look around the headers (the exhaust pipes that connect to the engine block). There will be thick (6mm+) spark plug wires connecting to each one. The other end of the spark plug wires is connected to the distributor cap. The front spark plugs are easy to replace. However, because of the tight space, the ones facing the rear are a bit more challenging. Also, do not use a regular socket to replace the spark plugs. If you don't already have one, pick up a spark plug socket at your local auto parts store that will fit the spark plugs on your vehicle (5/8" I think).
Old 11-05-2003, 03:10 PM
Sexy beast's Avatar
Sexy beast Sexy beast is offline
Banned
If you don't have experience changing sparkplugs don't go touching the engine...you'll just get yourself into a very expensive mess.
Old 10-26-2004, 09:19 AM
Touchstone8 Touchstone8 is offline
Re: okay help
I was seeking some help with our '93 Taurus station wagon when I came across your forums in a search. My husband has always done his own repairs and maintenance, however, he could NOT get the rear spark plugs out in this car. Is there some kind of trick to it?
Old 10-26-2004, 10:30 AM
denisb denisb is offline
I know on my 97 (it's got the Duratech motor), the plenum has to come off. Thanx Motomaster engineering I beleive my mechanic said it was a two hour job just to replace the plugs. Not backyard mechanic friendly.
Old 10-26-2004, 01:04 PM
Re: okay help
Thanks, Denisb. Not sure if that helps, but I'll let him know.
Old 10-26-2004, 02:17 PM
mwt mwt is offline
Re: Re: okay help
The discussion on whether or not the plenum has to come off or not has been gone over a million times over at www.taurusclub.com
Several people including me have performed plug changes n the Duratec without taking the plenum off. It is a "by feel" job meaning you can't see what you are doing but it can be done in less time than doing it by taking the plenum off. By not taking the plenum or Upper intake manifold off you do not expose yourself to
1. vacuum leaks
2 debris getting in you engine
3. stripped bolts by overtorquing the bolts back into aluminum.
Mike
Old 10-26-2004, 09:41 PM
Re: okay help
Thanks, Mike. And thank you for going over it yet another time. I searched that other site but didn't find the thread on this topic. He's going to give it another try this week-end using the method you mention.
Old 10-26-2004, 10:03 PM
mwt mwt is offline
Go there and click on forums.
Then click on maintenance
then search sparkplugs
Mike
Old 10-26-2004, 10:13 PM
Re: okay help
Thanks again. There was my problem I bet, I was spelling spark plugs as two words instead of one.
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 03:27 PM
Okay, help me here dudes. street_racer_00 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 02-21-2005 10:38 PM
Is my truck okay!! Help!! Mulaka C/K 13 09-18-2004 02:28 PM
ECU code 15, checked ignitor/coil okay...help?! JimCRX '88 - '91 Civic | CRX | Wagon | Shuttlee 3 12-08-2003 03:02 PM
okay... help clear something up... mdnnccivicrcr '88 - '91 Civic | CRX | Wagon | Shuttlee 19 01-09-2003 08:41 AM
