Old 11-01-2003, 08:50 PM
marty5135 marty5135 is offline
Question Key Chime continues after key is removed
Hello; I had my Left brake light replaced (blown bulb) and oil changed at Jiffy Lube and since then the key chime continues after key is removed. Don't know if it is connected are not; can anyone advise: Car-2000 Buick LeSabre (that eats power window motors also!!!)
Thanks,
Old 11-01-2003, 10:05 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: Key Chime continues after key is removed
It depends on the speed of the chime as to what could be causing your problem. Your chime warns you of the headlights left on, your parking brake left on, or your key left in your ignition and the door open.
Since it is a 2000 Lesabre your problem might show up on a scan of your car computer systems and that would help isolate your problem.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 11-01-2003, 10:41 PM
Thanks,
It is a fast rate, like I have left the key in or head lights on; I have "twilight" feature; no indications that any doors "ajar" but I checked anyway. Does anyone think it is related to the recent bulb change, Jiffy Lube visit?
Old 11-04-2003, 08:25 PM
Flatrater's Avatar
Main GM Guy
Re: Re: Key Chime continues after key is removed
Take it to the dealer and have them scan the body computer, something will be out of whack and it will give you the clue on what is causing your problem.
I have seen many chime problems and assorted problems caused by a bad Body module.
ASE Master Tech
ASE Advanced L1
GM Master tech
Ding, Ding keeps going after key is removed happydog500 LeSabre 1 08-23-2007 08:34 PM
Heater continues after key out of ignition Icestar Windstar 0 01-01-2005 03:03 PM
Radio stays on after key is removed on 99 S10 shockley S-10 2 08-13-2004 02:43 AM
Power is on after keys are removed honda2man76 Accord/TSX/Accord Hybrid 2 07-19-2004 08:42 AM
'04 Camry steering not locking after key removed! LoneWolf3 Camry/Camry Hybrid/Vista 3 05-12-2004 06:36 PM
