Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-01-2003, 08:49 PM
jedgxe jedgxe is offline
89 ciera problem with TCC
My daughter has a cutlass ciera sl 3.3 v6 160,000 miles.
It has an intermittent prob that I think has to do with the torque converter clutch. When driving at a steady 45mph it will sometimes shudder very harshly. The trans fluid and filter was changed less than 6 months ago and sometimes the car drives without the shudder, therefor I don't think prob is with TCC but rather with whatever controlls it. Only other prob is when engine is cold it idles fine but if you give it any gas when in Park or neutral it will try to die.
Doesn't do that in gear or when warm. The car also had the infamous code 42 which has not returned since I cleaned the anti-freeze from the crank sensor connector cleaned ground connection at c3i module and repaired coolant leak. I am a Mopar guy, so I'm not very familiar with GM engine controlls. What sensors and or controlls have any effect on Torque Converter Clutch and how would I test them ?? is it possible a coolant sensor could be faulty without setting a code ?
Various problems with my 1992 Nissan Sentra XE (4 door) benenarmor Sentra | 200SX (USDM FWD) 0 10-11-2009 11:32 AM
any help with tcc solenoid circuit code??? check engine excoupe23 3 Series 0 08-16-2007 03:00 PM
problems with 94 cutlass ciera badavey Cutlass Series 4 07-05-2007 01:05 PM
96 Voyager with TCC solenoid Code hmccray Engineering/ Technical 2 03-07-2007 12:52 PM
Problem with '89 ciera tape player Jeffe1988 Cutlass Series 1 12-31-2004 08:57 AM
