Go Back   Automotive Forums Car Chat > Cadillac > Catera
Old 11-01-2003, 02:47 PM
caddyman379 caddyman379 is offline
Question caddy tire/ignition problems
the key for the tires that snaps onto the lugnuts broke when i was changing it and where can i get a new one?
secondly, whenever i try my spare ignition key it wont start. the engine cranks and theres power to everything but it wont pump fuel unless i use the original key? what can i do to correct this?
mind you-the spare is the one i got from the dealership
Old 11-02-2003, 01:00 PM
bustedratchet bustedratchet is offline
Re: caddy tire/ignition problems
Did the wheel key come with the car ? There should be a key code that came with it for a replacement. I have sometimes removed the wheel locks by pounding a 12 point socket onto them. You spare ignition key sounds like it might be defective and not triggering the passlock,
Old 11-02-2003, 02:34 PM
re:
yeah, its the wheel that came with the car. what should i do about the spare ignition key and the tire lock? should i go back to the dealership or can i call GM or something like that?
Old 11-02-2003, 07:14 PM
Re: re:
Go to the dealer that made you the key tell them what's happening.Ask them about the wheel key also see what they say. Also look in your owners manual packet look or a card or something with the key code for the wheel key.
Old 11-30-2003, 12:13 PM
dala dala is offline
Cadillac spare Key
The spare key is only to unlock the door not start the car.
Old 06-09-2004, 10:15 PM
x_789 x_789 is offline
You need to have a key thats programed to start the car. Take it back to dealer.. They can also get you a key for the tires.. X
Ignition problem? Jeffstevehow Explorer | Explorer Sport Trac 1 06-22-2010 12:15 PM
Wig-wag headlights on a fleetwood caddy?!? No1BlackDragon Fleetwood 0 02-22-2010 10:00 PM
93 del Sol si wont start, something isnt getting power TunerFreak24 Del Sol 12 02-08-2010 01:17 PM
2000 m/c ss ignition control module problems ABADTAZ Monte Carlo 1 05-03-2009 02:53 AM
ignition problem, transmission problem, you name it problem 1hotmama Sable 1 04-20-2004 12:17 PM
