Go Back   Automotive Forums Car Chat > Honda > Integra
Old 10-30-2003, 12:36 PM
89teg 89teg is offline
89 integra still putting out a lot of emmmisions
I got an integra with about 250,000 miles on it and so far I've replaced the following:
air filter
plugs
wires
coil
IAC valve
Cat
oil change
The motor runs surprisingly strong with the amount of mileage it has so I think it's worth trying to make it drivable (smogging and registering it). But when it shifts it leaves a smokescreen behind it in little foul smelling clouds. I drove behind my friend driving it so see how bad it was. It's not terrible, just noticable when he shifts. Any idea of what I should work on to get it to stop the smoke and get it to pass smog?
Old 11-02-2003, 11:53 AM
homeslice0229's Avatar
homeslice0229 homeslice0229 is offline
To pass smog, I would recommend putting in some high octane gas (if you already aren't) and/or put in a bottle of "dry gas" in your tank. Run your car a little hard right before you take it to echeck, it would help get some of the carbon out b4 you are tested. That sould due the trick, it's just a temp. solution, but one that sould get you past e-check.
Old 11-02-2003, 11:27 PM
BullShifter's Avatar
Re: 89 integra still putting out a lot of emmmisions
What color is the smoke?
Old 11-16-2003, 02:56 PM
integrasedan integrasedan is offline
it means you have leaks going into the combustion chamber and will cause clouds at the tailpipe.
check your do a compression, check headgasket, piston rings, seals
Still smoking a lot after changing lower intake So frustrated Capt.torres Malibu 3 12-02-2009 10:49 AM
92 laser rs part out lots of parts no head plymouthlaserrs Classifieds 0 08-07-2008 11:20 AM
NOOB BUILD ~~~ Skyline R32 check it out...LOTS OF PICTURES GQ_KC WIP - Street 6 05-14-2006 10:59 AM
Completed: Mach 1 conversion. Check it out! Lots of pics white97ex Completed Projects / Gallery 19 10-17-2004 06:07 AM
New to sight. I just boughta 92 Integra could use a lot of help. grimald Integra 31 05-27-2004 10:09 AM
