Old 10-30-2003, 10:17 AM
SpyderEclipseGst SpyderEclipseGst is offline
14b Installation
Ok I should be recieving a 14b within the next week here and wondering what is needed to put the 14b on to replace my t25 on a 97 spyder. Is it a direct bolt on with the nessessary needed oil return lines etc. Or do I have to do some sort of bending or weilding, install kit to get everything to match up. Just asking because the only think ive ever installed was I/c pipes and bov. I usually dont do most things myself (fuel pump,clutch etc) just basic stuff (i/c pipes, intake, tune ups). Thanks and should have 1/4 mile times up asap after turbo is on and 550 injectors etc. Just need instructions so I can get it on take it to the track for the first time...Peace
GT35R Tuned GSX Spyder.
Old 10-30-2003, 10:57 AM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
it bolts on to the manifold fine, but you need a "J" pipe.
-Agim
Old 10-30-2003, 04:42 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
the oil return line is also different, i would suggest going to www.roadraceengineering.com and buying there "hacker/tweeker" kit. it comes with everything you need to install the new turbo on you car. i just got my 14b and that is what i am going to do. hope that helps.
Got AWD?
Some people buy super cars, other build them
----Click It, For Mods and Pics----
'95 Mitsubishi Eclipse GSX - For Sale
'05 Volkwagen Golf GLS TDI - My daily driver
'03 Ford Excursion 6.0L PSD 4x4
'13 Ford F150 FX4 SCREW 4x4 3.5L EcoBoost
'08 Buell 1125R
'83 GMC Sierra Classic K2500 4x4 - Future Cummins Swap
Old 10-30-2003, 10:01 PM
kjewer1 kjewer1 is offline
AF - Advisor
Go to www.vfaq.com, instructions are already there.
Here is the short version. The turbo bolts right on. You'll need a feedline kit for about 50 bucks from the major vendors, or the parts from a 1g. The return line is different as 95gsx said. You can get the 1g part, or just file the bolt holes closer together. Also, the bolts that hold that drain line to the turbo are different. No big deal, just be prepared. The water lines are next. Swap the front with the rear and bend slightly to fit. Tom made notes about that in the vfaq in red. Or as always you can buy the 1g parts. The turbo inlet pipe will fit right on, as will the O2 housing and exhaust.
Its all bolt on, and should take a first timer 6-8 hours. I think I've done the swap is as little as 3 hours. Not that big of a deal once you've seen it
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-31-2003, 12:49 AM
Re: 14b Installation
Great, by next weekend I should have it on. I will be going to the track hopefully that next wednsday. Ill post my 1/4 times as well as a dyno run at the shop. Hope for the best...!
Whats the best way to install side skirts? Sonic Eclipse Exterior and Wheels 8 04-06-2009 10:51 AM
installing aftermarket cd player jwhite85 General Discussions 3 03-30-2009 10:52 AM
14b install gsxeclipse97 Off-Topic 27 09-17-2005 01:15 AM
14B install questions DragonofBC Off-Topic 3 08-06-2005 03:39 PM
14b installed, but doest feel that strong. Killa_DSM Engine, Transmission and Drivetrain 21 04-27-2005 10:46 AM
