Old 09-05-2005, 02:02 AM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
Thumbs up 14b install
Well.. the turbo finally died today and lucky me i was on my way home when it kicked the bucket. I went to my friends house today and we started putting the 14b in but not done yet. Still have to put the water lines in and now i have to go to the dealer and get a couple of gaskets for the oil return lines. Removing the stock oil line was a bitch the bolts in the turbo and on the block didn't move for shit. Any how we got that out and now the process of putting the new turbo in starts tomorrow morning. I have a couple of questions here
1 why are there no cracks in the exhaust housing of the t25 and its been on there for almost 10 years now?
2 what is the highest psi i can run on the stock fuel system?
3 what the hell were the mitsubishi people thinking putting that small
ass turbo on the car?
4 I counted the blades in the t25 and there were 12 and also in the 14b and there were 12 so what makes it such a better turbo? From what i can see the the inlet is the same size the exhaust housing is the same size. So where is the major difference between the to
I could have gotten a ticket today because there was so much smoke coming out of my exhaust that it was hard for me to see the cars behind me. Good thing for me i already got my inspection done before that part died completely
I will keep u udated on the progress of the swap
MODS
, 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo
and the ac still doesn't work and its been almost 3 years
Old 09-05-2005, 10:40 AM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: 14b install
1. You lucked out with the T25
2. Around 17psi if you rewire the fuel pump, but get a walbro 190.
3. Cheaper
4. Its a bigger turbo, the inlet size is bigger, compare it with the t25, the compressor is also a little bit bigger i believe.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 09-05-2005, 08:02 PM
Re: 14b install
I see. Well i got the turbo in today but i don't have the oil line still and i have to go down to the mitsu dealer and get the gaskets for the 14b and for the 2g line that goes onto the oil pan, i also have to get the bolts that go onto the bottom of the turbo.
Well thats all for now but i hope to have it running by this weekend if i can get the money for that damn oil feed line..
MODS
Old 09-05-2005, 10:43 PM
Re: 14b install
Its a 1g line that goes to the pan, not a 2g
95 Eclipse GS-T
Currently:
Soon lol
Old 09-06-2005, 12:09 AM
Still_Good Still_Good is offline
You can safely run about 12-14lbs of boost on a 14b on the stock fuel system.
Above about 17psi the 14b just blows hotter air and really doesn't make you any faster.
The stock interheater is also a big limitation, and should be upgraded when you go with a bigger turbo.
Adding a larger fuel pump will most likely overrun your stock pressure regulator, resulting in an abnormally high fuel pressure. You will need an AFC and some tuning knowledge to get around this issue, and its a hack way to approach things anyways.
A set of 550 injectors is about $250 new, and an AFC can be found used for ~150. The 14b wont overrun your stock fuel pump, so you can leave that, and with the bigger injectors and AFC you'll be able to push the turbo to its limit of 17psi.
Feel free to PM me if you have any question about the 4g63 or tuning, I have more experience with it that I really ever wanted to.
Old 09-06-2005, 07:40 AM
Re: 14b install
Umm with a 190 u wont over run the stock FPR and you can stay on stock injectors as long as u rewire the fuel pump with 10 gauge wire, you can run 17psi
95 Eclipse GS-T
Currently:
Soon lol
Old 09-06-2005, 02:36 PM
Re: Re: 14b install
95gsxracer said that i can use the oil line from the t25 i will just have to drill new holes for the for the turbo and use the smaller bolts there I haven't even started looking at the fuel pump yet. Does it show on vfaq how to rewire the fuel pump? Im ordering the oil line today from rre so i guess it will here on thursday at the latest and i have to get the gaskets on thursday also.
MODS
Old 09-06-2005, 05:15 PM
Re: 14b install
With the 1g oil lines, you dont have to drill or anything, they fit perfect.
vfaq has a rewire faq. Make sure to solder everything, no 3m clips, or any crap like that. Solder, solder, solder!
95 Eclipse GS-T
Currently:
Soon lol
Old 09-06-2005, 08:55 PM
Re: 14b install
Well the ss line is on the way but it won't be here until tuesday next week. So i'll be carless untill then. I guess.... Well anyway i had one other question I've been searching around and i can't find the cfm's for the 14b some say its 405 and others say its 450 will someone please set the record strait
MODS
Old 09-06-2005, 09:32 PM
Re: 14b install
its probably 450
95 Eclipse GS-T
Currently:
Soon lol
Old 09-06-2005, 10:10 PM
Re: 14b install
so it flows 200 cfm's more than the t25
MODS
Old 09-06-2005, 10:13 PM
Re: 14b install
ahh crap, now i cant remember lol, im almost positive i saw 450 somewhere
95 Eclipse GS-T
Currently:
Soon lol
Old 09-06-2005, 10:17 PM
Re: 14b install
yeah thats what i read on dsmtalk that it was 450 so im just trying to get the right numbers. Dsmtuners said 405 so..
MODS
Old 09-06-2005, 10:19 PM
Re: 14b install
eh, probably somewhere in between lol
95 Eclipse GS-T
Currently:
Soon lol
Old 09-07-2005, 06:40 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: 14b install
Spending 50 bucks on the 1g return line is a waste IMO. It takes a little time with a file to make the 2g line work, and its a much better fit. The 1g lines come up a few mm short, and the shorter flex section is more prone to cracking. But what do I know
The T25 flows somewhere in the low-mid 20 lb/min range, and the 14b will do 30 lbs. Nearly a 50% improvement. AndI ran 25 psi all day on race gas for years, and 20 psi on pump gas. Don't quote a turbos limitations in terms of pressure, airflow is where the limit is. Same for fuel system capacity (though fuel rail pressure does affect the pumps capacity). And CFM is a shyte way to rate turbos, I'm offended by volume flow units. Mass flow is much more useful. 1 lb/min is 1 lb/min no matter how you slice it. But depending on what constants people use for temp and pressure, volume units can vary significantly (despite the "standards" that are in place.
and for the record, I'm slightly offended by all of these offers to PM with questions. Keep it on the board so everyone can benefit from the discussion.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
