Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-30-2003, 10:03 AM
civic98mi civic98mi is offline
Boost on D16Y5 ??? Need info
Ok, my car is a 98 civic hx, 5-speed, d16y5 sohc vtec-e I've already done the cliche things like body kit, coilovers, wheels, exhaust, intake, etc. etc. Now i'm looking for more power.
Problem is, a swap is near impossible (i live in muskeogn, michigan and hondas are rare and there really is no import scene whatsoever) My car stock has 115hp, so now i figure im at 125 tops (i, e). My question is, what can i do to increase my numbers on a somewhat low budget?
I was considering saving up for an EX turbo kit, but im not too sure. I know edelbrock just came out with one. But i've heard you can't turbocharge an HX, is this true? I know the catalytic converter is located inside the stock manifold, but wouldn't it still work to do a turbo or header as long as i buy a manifold with secondary o2 sensor?
Also, would other bolt-ons for an EX work with my car (fuel rail, intake manifold, ignition, throttle body, etc.) I know anythign related with cams is out of the question since my car has a whacked version of vtec with a really weird rocker arm setup. Any info would be appreciated. Thanks!
Old 10-30-2003, 10:20 AM
91CRXHF 91CRXHF is offline
Send a message via AIM to 91CRXHF
ok the edelbrok kit should bolt up to your car since they are both d series motors you may ave to do some adjusting also have you looked into just changing your head?...and go to a Y8 head? is it posible im not too familiar with your modle but that may make the difference there and you could get the stock ECU out of a junkyard EX. if it would fit. also a drag kit should botl on to but you would need some fabrications. or have you looked at FMAX....or Rev Hard they also have kits available for hondas and acuras.
Old 10-30-2003, 10:34 AM
Re: Boost on D16Y5 ??? Need info
yeah i've read that the only difference between the 2 motors is the head and ecu, and exhaust. So i'm guessing the only thing i'll need to fabricate is probably the manifold and downpipe? I haven't heard of fmax or revhard, but i'll look into it. Thanks 91CRXHF
Old 10-30-2003, 11:17 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: Re: Boost on D16Y5 ??? Need info
www.turbod16.com
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 10-30-2003, 11:52 AM
Re: Re: Re: Boost on D16Y5 ??? Need info
Originally Posted by BLU CIVIC
Thanks for the url, i'll check it out.
Vehicle info needed biggie360 Shop Owner Advice 0 03-27-2009 11:12 PM
Struts Need Replacing Need Info Install brock02 Cutlass Series 2 01-13-2008 10:41 AM
need info on what ecm mods a tuboed 420a needs. rs2evo Engine, Transmission and Drivetrain 3 04-21-2007 03:32 PM
HELP!! Need to cast or mold...need info!!!! modelfreakca Car Modeling 5 03-13-2007 02:07 PM
i need help with my crx... i need info zkhan Exterior | bodykits | Lighting 2 11-27-2006 12:11 AM
