Go Back   Automotive Forums Car Chat > Volkswagen > Golf
Old 10-29-2003, 10:54 AM
vwjoe vwjoe is offline
Send a message via AIM to vwjoe
hard start when dry wont start when wet
Having problems starting my 85 golf hard start in the morning when its dry when started it wont do it again for the day, but wont start when its raining out i thinks its the ignition coil or distributor cap please help.
Old 11-03-2003, 10:59 AM
dustIYF1113 dustIYF1113 is offline
first start with the least expensive possibility first check your spark plugs and wires replace accordingly next check distributor cap and rotor
(if u plan on doing it ur self u might as well do a full tune up(plugs wires cap rotor fuel filter and air filter (some may disagree but it cant hurt)) but do things in stages start it up after each step to see if it makes a difference. id start with the electrical aspect since thats what it sounds like!!!!!!
Old 11-10-2003, 07:40 AM
Re: hard start when dry wont start when wet
thanks i put in a new ignition coil and it seems to workin fine now but i will chk air filter and plugs i put already i will chk the fuel fitlter as well thanks
Old 01-07-2005, 09:22 AM
super_dawn super_dawn is offline
98 Golf 5 sp Manual
I'm having the same problem with my 98 Golf. If it's raining or snowing it's almost impossible to get the car started - it turns over but doesn't "catch". The car will chug and shake a bit if I hold the ignition key for a couple seconds. It eventually starts after 9 or 10 tries if I pump the gas pedal. The distributor cap, spark plugs and wires were all replaced a year ago. Any ideas?
I'm also having a bizarre issue where my keyless remote lock doesn't instantly lock the door. When I push the lock button, the 'alarm ready' light goes on but the doors don't lock for up to a minute.
Old 01-08-2005, 11:44 PM
Problemsolver Problemsolver is offline
I think you have 2 different problems. First the remote unlocking problem , Have you tried replacing the battery in the remote?
Seconed there is an service bulliten for canadain vw's where they update the heat riser for the intake air sensor. call your dealer and ask about it. Something about the air causing the fuel to freeze in the intake.
Old 01-09-2005, 04:47 PM
boschmann boschmann is offline
I'd say the door lock problem is a vacuum leak. Can you hear the pump motor in the luggage area run for a prolonged time? As for hard strarting & sputtering when wet, the ignition coil is the most common culprit. Spray some water on it & see if it starts acting up.
Hard Start...Lifters knockin after start-up for like 2 min. 2000 Chevy Silverado 5.3L Silverado_Dude Silverado 8 08-21-2009 07:28 PM
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
97 yukon wont start yukon45427 Yukon 1 06-23-2009 07:24 AM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
long starting, fuel pressure wont hold when engine turns off. lav mechanic Taurus | Taurus Wagon 10 10-07-2004 05:33 PM
