Old 09-15-2004, 04:20 PM
lav mechanic lav mechanic is offline
Unhappy long starting, fuel pressure wont hold when engine turns off.
I have a '96 Taurus with 170,000 miles. It takes a long time to start my engine. I checked the fuel pressure and noticed as soon as I shut off the engine, the pressure drops to zero. I checked another 96 Taurus and fuel pressure remains after engine shuts off. I changed the fuel pump, fuel filter, and pressure regulator. Still, fuel system will not hold pressure and takes a lot of cranking to start engine. Is it possible that the fuel injectors are not holding shut when engine shuts off? I don't see or smell fuel but could it be leaking through the nozzle? I can not locate where the check valve would be on the supply side to the fuel rail. I've been told its in the fuel pump, but when I pulled out my old fuel pump I could not notice any check valves. There is a pulse dampener in the fuel line right before the fuel rails. Is it possibly located in here? Any insight greatly appreciated.
Old 09-15-2004, 07:44 PM
robz84monte robz84monte is offline
it sounds like the injectors are leaking. i'll nose around for a little more info and reply back tomarrow
Old 09-17-2004, 01:00 PM
ok looked at some diagrams and it seems the pressure should be kept in by the regulator and/or the pump. since you've already changed both of them i would check the injectors.
Old 09-23-2004, 10:44 AM
Cool Re: long starting, fuel pressure wont hold when engine turns off.
Thanks robz84monte. I'll post another message when I change the injectors. I guess the easiest way might be to go to a junkyard and swap out 3 injectors at a time and see if it makes a difference. I'm not sure if there are any easy ways to check specifically for a leaking injector.
Old 09-23-2004, 04:48 PM
86TATpi 86TATpi is offline
Do an on line search for reconditioned fuel injectors before you swap for junk yard ones. At least you'll get a warranty.
Old 10-02-2004, 12:56 PM
jc glass jc glass is offline
Replace Fuel pressure regulator. Test by crimping off return line before switching off ignition. (leaking fuel injectors is the most unlikely problem)
Old 10-02-2004, 04:40 PM
Re: Re: long starting, fuel pressure wont hold when engine turns off.
he already did
Old 10-06-2004, 09:27 AM
Angry pulse dampener?
I've changed the fuel pump, the fuel filter, the injectors (all 6), and the pressure regulator. The only thing I haven't changed is the pulse dampener. Also, when I changed my fuel pump, I looked at the OEM pump and didn't see anything resembling a check valve anywhere on the assembly. If I still feel motivated, I'll change the pulse dampener but at this point I'm about ready to drive it off of a cliff.
Old 10-06-2004, 11:57 AM
man this is a tough one, have you traced the entire fuel line to try to find any leaks?
Old 10-06-2004, 02:33 PM
still no solution
Thanks for all of your comments. The one about injectors saved me a lot of money when I changed injectors this weekend. I got them online from injectors4u.com for about 16 bucks a piece and they're warrantied. Unfortunately, I experienced no change with regards to fuel pressure or start time.
Rob, I checked all of my fuel lines and associated hardware especially by the injectors. I detect no fuel odors or leaks. Have you ever heard of the pulse dampener being used as a check valve instead of the fuel pump? I've been doing some research. It appears that in the pulse dampener there is also a check valve function.
Old 10-07-2004, 05:33 PM
to be honest i've never even heard of a pulse dampner (i even did a pretty thurogh search in alldata-an automotive manual data base- and i couldn't find any thing in there about it) what does it look like?
normally i wouldn't recommend just changing parts on a whim but for all that you've already changed (and as much as you've probably spent) i'd say that if isn't too bad then go ahead and change it.
