Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 10-26-2003, 04:42 AM
smokestak777 smokestak777 is offline
Send a message via MSN to smokestak777
Unhappy Engine Idels Erattically And Car Goes By Itself
I Have A 96 Ford Thunderbird 3.8l Recently I Was Driving And Felt What I Thought Was The Gas Pedal Move Beneath My Feet By Itself..when This Happend I Noticed My Car Was Hard To Stop,and When It Did Stop As Soon As I Let Off The Brake It Would Go With Out Me Touching The Peadle At All..i Stopped My Car Again, Put It In Park And Noticed The Engine Was Idleing Way Beyond Its Usual Limit..and As You May Guess When I Put It Bck In To Drive I Felt A Jerk Form The Tranny..as If I Had Put It In Drive With The Accelerater Mashed Down..can Anyone Tell Me What May Be Causeing This Problem????? Please?
Old 11-27-2003, 10:30 PM
TWSNNVA TWSNNVA is offline
I would bet it's a faulty MAF sensor. I had the same problem that you're experiencing with my 94, 4.6L, these both have the same MAF. The car likes to hang out at 1300-1700 rpm, tap the gas and the rpms drop. Disconnect the plug from the MAF and drive the car, the computer will go into a failed state and base airflow on rpm, rather than what the MAF reports. The car will drive horribly for a minute or so, with the rpm dropping to 300 or lower, and the car may stall once or twice, after you drive it for a few minutes it will run as it should. Autozone has the cheapest one I could find it's a remaned cardone. Good luck.
Old 12-21-2003, 07:54 PM
4ss4s1n's Avatar
4ss4s1n 4ss4s1n is offline
Send a message via Yahoo to 4ss4s1n
Yea,thats pretty much it.I was reading recalls a couple days ago and a recall came along that had the exact same description.It affected most 88-97 Thunderbirds and Cougars with the 3.8 and 4.6 liter.Its basically the MAF sensor.You could do that or if you got the car when it was new,the recall might cover it.
Old 01-16-2004, 06:15 PM
97tbirdman 97tbirdman is offline
may be the throttle sticking if not the MAF. check that as well, some wd40 on the linkage should fix it.
Old 02-02-2004, 06:53 PM
dkm dkm is offline
Re: Engine Idels Erattically And Car Goes By Itself
Thank You THANK YOU THANK YOU! I have had this problem for a couple of years now (94 tbird) and have been posting and this is the answer Thank you so much!
DKM
Old 02-02-2004, 07:22 PM
dkm dkm is offline
P.S.
Where did you find that recall info?
DKM
Old 02-02-2004, 08:06 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
some times the carpet on my 92 tbird would hold the gas pedal were it raise the rpms enought to be aggrevating
Old 02-05-2004, 11:11 AM
Titan4 Titan4 is offline
I had a similar problem in my '89 T-Bird once, but it happened when I applied the brakes while my cruise control was on. I managed to stop at a traffic light, but the car was still trying to go. Turns out that my brake light switch was bad so in addition to it not lighting my brake lights it was also not telling my cruise control to disengage. I think the switch was about $11.00 from the dealer. Mounts right on the brake pedal.
Service Engine Soon Light and Car Does Not Start NeoSaiyan7 Intrigue 2 08-11-2007 09:35 AM
Engine Light on and Car won't start! SSAlero Alero 6 01-31-2007 07:40 PM
2000 Neon Hit the gas and car goes put-put Jadavisit 2nd Gen 00-05 4 08-25-2005 09:50 AM
Engine Idels Excessively,and Car Goes By It Self smokestak777 Thunderbird 2 11-12-2003 10:35 PM
Engine Warning Light! And Car driving poorly, Help Laker '88 - '91 Civic | CRX | Wagon | Shuttlee 1 09-30-2002 04:27 AM
