Old 10-24-2003, 03:59 PM
NightWalker17's Avatar
NightWalker17 NightWalker17 is offline
Send a message via MSN to NightWalker17
Lightbulb D15b Vti Swap
Alright i have a question about my civic and a b15b... Now i have a 95' Civic DX and i want to get the D15b To put in it. So my question is is that do my axels and what not work stock with this motor and what not becuase i want to make sure its a direct bolt in. The only thing that i wuold need is the ECU becuase im ruuning and 1.5 Non- VTEC. So i was wondering if any one could help me on this to make sure my swap goes the wy i want it to go. Also is there any thing i have to do with the wireing and what not to make the harness fit and stuff. so ya if you could help me out that would be great!!
Old 10-24-2003, 05:03 PM
By the way this is the Vtec version of my motor thats all i really wanted from this swap and what not.
Old 10-24-2003, 06:32 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
I'm confused here...
'95 DX's came with a D15b motor, NOT a B15b. There's no such thing as a B15 motor, just a D15. There is no VTEC version of a D15 that I know of, the motor you are after I believe is a D16Z6 or a D16Y8, the Z6 is the '92- '95 Si hatchback as well as the '92-'95 EX motor, and the Y8 is the '96-'00 EX motor, both of which have VTEC. Your current motor is the D15b7, correct?
Recheck your engine code on your current motor in your Civic, and we'll see what we can figure out from there.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 10-24-2003, 06:35 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
You should just need the ECU and to run a few lines for Vtec. You should be able to use the stock axles, mounts, etc since it's all from a D-Series engine. Depending on what engine you had before you could use the stock tranny too (not CX or VX thought [I believe]).
Old 10-24-2003, 06:38 PM
CivicSpoon's Avatar
There is no Spoon
Re: D15b Vti Swap
Originally Posted by SilverY2KCivic
There is no VTEC version of a D15 that I know of, the motor you are after I believe is a D16Z6 or a D16Y8, the Z6 is the '95 Si hatchback motor, and the Y8 is the '96-'00 EX motor, both of which have VTEC.
Yup there is a D15b with Vtec, it's pretty rare though. Came stock in Civic Vti's in Japan. But the really older ones (pre-'92) had carbs instead of fuel injection. I just found out about them a week ago when i saw it on http://www.hmotorsonline.com/shop/sc...age&item=30019
Old 10-24-2003, 07:45 PM
Cali Guy
Re: Re: D15b Vti Swap
Ahh, thanks for the FYI on that. I went out on a limb and said "not that I know of" rather than "there isn't" just in case. I really wasn't sure, but that makes sense. I also just read the topic of this states that his car might be a VTi model as well or at least using that engine. :o
hessemer69 on AIM
Old 10-25-2003, 02:16 AM
ya Thats where i was going to get my motor from Hmotorsonline so ys when i saw that i was suprised y sel so do you think its even worth it i mean do you like its a good idea or should i just throw it away?
Old 10-25-2003, 06:48 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: D15b Vti Swap
If you're feeling really cheap you can use just the longblock, as it will mount up to your tranny, and all the other ascessories in the bay. Then you only have to pin the vtec wires on the D15B's ECU, but you should get either a Si, or EX tranny to take full advantage of the D15B.
Old 11-07-2003, 11:23 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
hey, not to hijack this thread or anything, but do any of you know about compatibility of this motor as far as pistons, rods, bearings, etc? Is it the same as the other d-series? I am thinking about going with this motor on another swap i'm doing...
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 11-07-2003, 03:55 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Re: Re: Re: D15b Vti Swap
I just got my D15b a week ago. I'm still waiting for the P08 ecu. As far as the motor goes it is a 1.5l bottom end, so vx,cx bottom. The head is a Z6 head so you use all z6 head stuff. If you do some research there is plenty of info around. Any other questions just ask. If your just looking for Vtec then just swap on a z6/y8 head. All is interchangable because it is a d series motor.
Check out my car here My 91 Hatch
Old 11-08-2003, 09:32 PM
CivicSpoon's Avatar
There is no Spoon
Re: Re: Re: Re: D15b Vti Swap
[quote=Dumped91Hatch]...As far as the motor goes it is a 1.5l bottom end, so vx,cx bottom. The head is a Z6 head...QUOTE]
Thank you so much you just saved me a lot more $$$ than I have to spend; i had no clue that's what the motor was.
Old 11-13-2003, 05:42 PM
kdog kdog is offline
d15b
ok guys let me help you out a bit.....I have had one of these engines for a while and have done quite abit of research. First off, everything in your engine is interchangable as long as your current engine is mpfi. all trannys 89 and up, not 88 because of spline differences, will fit. Use the P08 ecu but get it from hyperducktuning.com. I have one and I wouldn't chose any other ecu. The RPT chip works best. When you wire the vtec make sure you wire the oil switch behind it as well.....trust me. This engine thrives on lots of cold air and high RPMs. It can go to 8k stock without batting an eye. As for the internals, you are partially right, the top end is a z6 head, and you'll need a 92-95 VX timing belt when you install. The bottom end is similar to the d15z1, but the rods are bigger and so are the journals. As far as I know so far no one has been able to locate upgraded lower end parts except for the pistons. In my opinion you can't get a better bang for your buck and it's one of the toughest out there. I've ran about 15 bottles through it and seems to get stronger each time I drive it. Just be careful who you buy it from. If you pay more than 500 shipped your getting ripped off.........e-mail me if you have questions... [email protected]
hope this was some help!
later
Old 11-13-2003, 07:00 PM
Since it is a z6 head you use the z6 timing belt you could use the vx I suppose but it is vtec-e. Oh and it only revs to 7200 so your tach is off. Unless you use an ecu that has a higher redline. Here is a site on the Jdm D15b,http://asia.vtec.net/article/d15b/ most of it is accurate.
Old 11-13-2003, 09:51 PM
d15b
I must disagree. You are right, it is a d16z6 head however the bottom end is different then a d16z6. The bottom end is most similar to a d15z1 hence the reason you use a vx timing belt. As far as the rpms are concerned, I said that it can safely rev to 8k I didn't say that the stock p08 ecu would allow it to do so.
Old 11-13-2003, 09:53 PM
Re: D15b Vti Swap
basically what I'm saying is that a z6 belt will not fit...
question about D15b vtec swap crxman321 '88 - '91 Civic | CRX | Wagon | Shuttlee 2 04-27-2005 04:55 PM
info on civic d15b vti 3 stage vtec jdm CIVIC-VTI JDM Motor & Parts info/chat 0 10-06-2004 06:02 AM
JDM D15B motor swap help milk215 JDM Motor & Parts info/chat 1 03-08-2004 08:07 AM
d15b head swap tylertime Engineering/ Technical 8 04-15-2003 11:00 PM
